Had alignment performed today.
Old Nov 7, 2019 | 04:04 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Had an alignment done to after replacing inner an outer tie rods.
Here is the print out.
Looks like rear toe is off. Any ideas?
Old Nov 7, 2019 | 04:45 PM
cristo's Avatar
cristo
Alliance Member
Why didn’t they adjust the rear toe?
It’s a little bit of a pain to do, but if
I can do it at home with simple tools,
they certainly could have and should
have also.
Old Nov 7, 2019 | 04:49 PM
OCR's Avatar
OCR
Looks like everything in the rear is in the "red".
On one hand, there IS very little adjustment capability in both the front and rear. The rear could be out of adjustment capability by normal OEM means.
You'd have to buy a set of adjustable arms to allow everything to be adjusted into either spec. or your desired values.
I know my 05, I had to buy both adjustable rear arms and adjustable plates for the front.
From the factory, they have too "little" front camber and too "much" rear camber. My brother fought this for years when he worked at a BMW dealership. Being a manager, he had to TRY to satisfy both the customer, the insurance companies and the dealership in trying to fix crashed Mini Coopers.
I asked him a ton of questions before buying mine. Hours worth, in a coupla sittings..!
Mike
Old Nov 7, 2019 | 04:51 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
I was thinking I would have to get rear lower adjustable arms. I have stock suspension. If there a adjustable plates for the front?
Old Nov 7, 2019 | 05:11 PM
OCR's Avatar
OCR
shrevemini -
IS...there adjustable plates, like I mentioned, I had to buy a set for myself.
Check out most any internet Mini parts outlets. Be sure to buy "street" oriented rear arms (and front kits). Do NOT buy rear arms that have spherical bearings in them for the street, despite what some may say. Buy either rubber or urethane bushings for the rear. Ireland has both stock and adjustable front plates. After doing some research on my own, I found the Ireland to be the best choice for front kits also...for me, and my 05, JCW Mini..!
Ireland Engineering parts for my car.
https://www.iemotorsport.com/products/mini-parts/
Mike
Old Nov 8, 2019 | 03:40 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Looks like they saw the total toe int he rear being ‘green’ and said “good enough!” Seems pretty lazy...
Old Nov 8, 2019 | 05:41 AM
cristo's Avatar
cristo
Alliance Member
Your rear camber is good so you
don’t need adjustable rear arms.
You can adjust rear toe without them.
That will change the camber a little
but it will still be good.
Old Nov 8, 2019 | 06:12 AM
shrevemini's Avatar
shrevemini
Top Answer: 1
Well I had it done at Pepboys. I going to call Mini in Pensacola to see what they would charge to adjust rear end.
Old Nov 8, 2019 | 07:02 AM
Capt_bj's Avatar
Capt_bj
I was gonna ask if this was done at the dealer
when I bought new tires for '15 R59 I told the tire shop to align it
they came back and said they could do the front, but the rear needed an adjustment they could not do for need of a special tool and recommended I have it done at the dealer. Charged nothing.
subsequently went to dealer and everything was put to spec . . .
Old Nov 8, 2019 | 07:51 AM
cristo's Avatar
cristo
Alliance Member
The special tool is handy but not
at all necessary.
lazy, lazy, lazy.
Old Nov 8, 2019 | 09:47 AM
Capt_bj's Avatar
Capt_bj
I appreciated the honesty of the place ... they felt they could not do it right so they advised me to spend my dollars where I'd get complete satisfaction.
OP is here because someplace tried the other way and failed.
Old Nov 8, 2019 | 03:55 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Well I got an appointment next Friday at Mini of Pensacola.
So let's see how it goes
Old Nov 16, 2019 | 04:16 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Well I had my alignment done at Sandy Sansing in Pensacola. They did an excellent job. They got everything thing to spec. Like driving on rails.
chrisdurand
Suspension
Jun 18, 2017 05:47 PM
vanguard
Feb 20, 2013 08:08 AM
kellini
Suspension
May 25, 2012 05:06 PM
RedSkunk
Suspension
Mar 2, 2007 10:43 PM
ggp
SCCA Solo and ProSolo
May 22, 2004 02:24 PM
