Super charger pully upgrade
Old Sep 21, 2019 | 03:36 PM
2004minicoopersworks's Avatar
I was thinking about a supercharger pully upgrade, I have a 2004 Mini Cooper S works. Will I have any problems with a kit?
Old Sep 21, 2019 | 04:17 PM
Eric_Rowland's Avatar
Eric_Rowland
Care to be more clear on the question?
A Works car has a 11% reduction pulley relative to regular OEM, so you don't get much with a 15%
Old Sep 21, 2019 | 07:37 PM
cooper48's Avatar
cooper48
Best to stay with a 15% which is the best bang for your buck that you can make to a MINI. You'll love the hp increase. Going down to a 17% makes sense on a track car but not on a street car because it will shorten the life of your supercharger.
Old Sep 24, 2019 | 06:07 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
By far the best bang for the buck upgrade for the R53.
If you have a JCW your supercharger already has a smaller pulley so going to a 17% will show the better improvement as it will be a bigger difference from the stock JCW. This will also gain you more low end torque as you will have more boost on the low end.
https://www.waymotorworks.com/wmw-pulley-package.html
You will also need a JCW specific puller to do the job.
https://www.waymotorworks.com/john-c...uller-r53.html
Old Oct 28, 2019 | 01:25 PM
glark's Avatar
glark
I use 99oct on my S5, as I have a convertible what sort of 0-60 times do you feel I would get? Perhaps increased by half a second 4ish?
Tutuapp 9apps Showbox
Old Oct 28, 2019 | 04:06 PM
OCR's Avatar
OCR
What is..."4ish"
Half a second 4ish...!?
Mike
Old Oct 28, 2019 | 04:09 PM
OCR's Avatar
OCR
2994mcw -
Do you have a larger damper? ATI makes a slightly larger damper that is also MUCH better quality than the stock damper. I believe the larger ATI will spin the blower another 2% over.
Mike
Old Oct 30, 2019 | 11:40 AM
Derek86's Avatar
Derek86
From a JCW pulley (11%ish) to a 15% pulley is a lot of work for not a lot of gain. Money and time would be better spent upgrading other failure prone components, including the crank pulley (previously mentioned), which you can get over-sized to increase your supercharger RPM.
marksmith
Oct 29, 2004 10:26 PM
David Singgih
Aug 25, 2004 04:50 AM
bleeblah
Aug 12, 2003 02:04 PM
PatrickH
Feb 22, 2003 07:06 PM
