R53 powerflex gearbox inserts/mounts help
Old Feb 20, 2019 | 12:00 PM
Serafin's Avatar
Serafin
hello guys. So i triednto install these the other day. Remibes the gearbox Mount. Took out the 2 black inserts and the blue hard plastic inside the bushing.
I was able to mount the small powerflex on the font side.
But had a really hard time mount the the rear ones ( bigger )
should i trim the top part that goes in? Really baffled my this.
So so i ended up using the front party only and reinstalled the thin black insert on the rear. Am i going to have i issues with this?
Thank You
Old Feb 20, 2019 | 09:47 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We use a big pair of pliers and squeeze it in. Or you can take the entire mount off and use a vise to kinda press it in.
Old Feb 20, 2019 | 10:33 PM
Serafin's Avatar
Serafin
i tried that and it comes back out. Or am i not putting it all the way in? Will it lock-in place ?
Old Feb 21, 2019 | 12:40 PM
WayMotorWorks
Vendor
Yes it will usually stay in. You can also use a little grease to make it slide in easier.
Old Feb 21, 2019 | 01:01 PM
Serafin's Avatar
Serafin
yes i used power lube. Ok will try again and have to buy a wide mouth pliers thank you
barnoun
Jul 1, 2014 08:30 PM
R35P3CT DA M1N1
Jun 22, 2014 02:05 PM
astroBlackMetallic_Mini
Suspension
Aug 26, 2013 09:58 AM
ggcadc
Jun 15, 2011 10:50 AM
VELOCITYCRUNCH
Suspension
May 20, 2009 09:44 PM
