Suspension Gearbox mount insert vs powerflex
Old Aug 18, 2013 | 08:42 AM
astroBlackMetallic_Mini's Avatar
Found this on eBay. Was wondering how exactly it installs for one.
Second, wondering if i could get away with this vs a powerflex bushing. I'm turning not to induce NVHs, hence the thought of that insert vs PF.
Thoughts?!
http://www.ebay.com/itm/SPF2552K-Sup...-/321167927060
Old Aug 18, 2013 | 09:29 AM
Da_Ghost's Avatar
Da_Ghost
I have the powerflex ones for the gearbox, but the install is the same. You remove anything in the way of the mount, put a jack under the trans so it stays where it is, remove the mount, insert the inserts (reduntant sentence is reduntant), bolt everything back together. There's most likely a how-to on here, I did mine last year, so I can't tell you step-by-step (stupid memory), but it's pretty easy to do.
Old Aug 18, 2013 | 09:59 AM
vietnameeh's Avatar
vietnameeh
i have the same gearbox insert.... straight forward install
i only had trouble when i had brain fart and accidently started messing with the jack and things didn't line up too right
however i guess that side makes no difference because thats the only insert i have on right now
Old Aug 19, 2013 | 05:43 PM
You have the eBay one?
You can't tell a diff?
Old Aug 19, 2013 | 06:47 PM
vietnameeh's Avatar
vietnameeh
Yes I have the super pro
I'm sure it helps but I only put that in no difference when I put the upper insert (2003 upper mount) then there was some stiffness
I'm
Sure it compliments all other inserts
Old Aug 26, 2013 | 09:58 AM
mgrant's Avatar
mgrant
I recently put both the lower mount inserts and transmission mount insert (Powerflex ones) and noticed an improve throttle response (engine doesn't rock as much) but did notice a NVH when RPM are low (1-1.5K)
NVH arent noticeable during normal driving but if you do a lot of city driving (stop and go) I can def see the vibrations getting annoying
patsum
26
May 29, 2021 06:29 PM
minimofo
Sep 30, 2015 12:26 AM
SeattleF56
Sep 3, 2015 03:01 PM
Sep 3, 2015 02:06 PM
