Anyone running 10w30 oil ??
Old Aug 26, 2018 | 01:11 PM
rfins's Avatar
rfins
About due for a oil change at 60,000 miles.
I was thinking about using a full synthetic 10w30 oil........(I thought it may give the turbo a little better protection.)
Anybody else ???
Old Aug 26, 2018 | 02:33 PM
cristo's Avatar
cristo
Alliance Member
If you feel you need a little more protection then
consider 0w40 or maybe 5w40 if you live in a warm climate.
Hopefully something A3/B3 and LL-01 certified.
Old Aug 26, 2018 | 03:57 PM
entropy1's Avatar
entropy1
You can have any oil you want, as long as it’s LL-01 certified. Head to Walmart and grab a jug of Castrol 0W-40 or 5W-40 for around $25.
The LL-01 certification means it has to pass a turbo test designed by BMW, among a slew of other tests.
Old Aug 27, 2018 | 11:50 AM
Just make sure its LL-01 and meets the BMW/MINI stardards, I was 5w-30 and now on Molygen 5w-40.
Old Aug 27, 2018 | 12:14 PM
gumbedamit's Avatar
gumbedamit
I'm sure I'll get a lot of flash about what I'm going to say. Thicker oil does not protect your engine better than manufacturers recommended oil, it may in fact hurt your engine. Today's engines are vastly different from the engines 20 or so years ago. Modern engines use very close tolerances and if you use a thicker oil, it may not get to the surfaces it's meant to protect causing premature wear and higher oil pressure. I could go into more detail, but the logic is already there. I would go with what the manufactures recommends. just my 2cents.....
Old Aug 27, 2018 | 01:57 PM
entropy1's Avatar
entropy1
Exactly. And it’s worth mentioning, LL-01 oils are about as good as they get in the auto industry... and they have the test results to prove it (rather than marketing gimmicks).
Molygen does NOT have LL-01 approval, fyi.
Old Aug 27, 2018 | 02:34 PM
Good point. Not approved by bmw/mini ll-01 program, but meets the specs. MINI used to have 4 aftermarket oils posted before that are approved which you can find in the forums here and here https://garywright.smugmug.com/Motor...ly/Oil-Crisis/ .
I really like oil and been running it for a while now on both my R52 and R58.
https://products.liqui-moly.com/moly...n-5w-40-6.html
Keep in mind newer MINI engines now recommend this:
https://www.northamericanmotoring.co...r-ll-14fe.html
Old Aug 27, 2018 | 02:48 PM
entropy1's Avatar
entropy1
Yeah, I’m sure it’s fine oil. Just wanted to point out that there is a difference between “recommended for/meets” and “approved.”
David.R53
Aug 8, 2014 08:02 PM
IQRaceworks
43
Jan 21, 2014 04:59 PM
JakeBRG
Nov 7, 2003 10:20 PM
friedduck
Aug 5, 2003 11:15 AM
