Gauge Installation
Old Jun 11, 2018 | 03:55 PM
jtr58's Avatar
jtr58
Gauge Installation
Not sure whether I'm looking for encouragement or advice -- maybe a bit of each; both are welcome. I have a 2013 S R58 Coupe and I'd really like to install two gauges: water temperature and oil pressure. (Any thoughts on whether these are the two to install?) I've glanced at the installation instructions for the Marshall instruments on the CravenSpeed site. They seem pretty straightforward when it comes to the connections to the engine. But the interior wiring has me a little concerned.
Anyone out there connected these gauges before? Easy enough?
Thanks, all.
Old Jun 11, 2018 | 05:54 PM
DneprDave's Avatar
DneprDave
I have, I used the Cravenspeed gauges and adaptors. It isn't hard, there is a rubber octopus looking thing on the firewall that you can route your wires through. It is just above the brake pedal.
I put a boost gauge, water temperature, oil temperature and oil pressure gauge on a home made mount, made of 1/16" aluminum and 2" ABS drain pipe the mounting screws on the gauges hold everything together.
Old Jun 11, 2018 | 06:04 PM
jtr58's Avatar
jtr58
DneprDave, really appreciate the response. (Did you have to take up the center console to wire in?)
BTW, your car looks fantastic. Great work. (You should think about marketing your work!)
Old Jun 12, 2018 | 07:00 AM
DneprDave's Avatar
DneprDave
I tapped into a light in the console to power the lights in the gauges, so yes, I took up the console.
Old Jun 12, 2018 | 10:03 AM
StephenM's Avatar
StephenM
Some really good info on gauge installation on pnwR53S's thread:
https://www.northamericanmotoring.co...n-project.html
Old Jun 12, 2018 | 11:10 AM
jtr58's Avatar
jtr58
Wow, StephenM, after viewing the link with the info on gauge installation... I'm thinking twice about installing my own gauges.
Thanks for the assist.
Old Jun 12, 2018 | 02:20 PM
drea-min's Avatar
drea-min
I had bothe the coolant temperature and oil pressure gauges, i recommend digital on both.
Old Jun 12, 2018 | 03:29 PM
jtr58's Avatar
jtr58
Nice, drea-min. What kind of gauges? Did you install yourself?
Old Jun 12, 2018 | 05:13 PM
stamp11127's Avatar
stamp11127
They are Auto Meter gauges - look close on the oil pressure.
Old Jun 12, 2018 | 06:55 PM
drea-min's Avatar
drea-min
Yes the gauges are from Auto Meter some parts are from various vendors and installation i did it myself, tapping and soldering takes some times and its a challenge for DYI. The hard part is where you removed the oil pressure switch and then adding the adapter Tee for the gauge and the exhaust heat shields needs to trim it a little.
Old Jun 12, 2018 | 07:05 PM
drea-min's Avatar
drea-min
First picture where all the wiring goes and inside under the steering wheel, second is the coolant temperature sensor, and third is the oil pressure sender, i used hydra-air hose from the tee and away from the exhaust heat, accessible and convinient
Old Jun 12, 2018 | 07:15 PM
jtr58's Avatar
jtr58
Drea-min, you do nice work. Appreciate you sharing.
Old Jun 13, 2018 | 07:01 AM
DneprDave's Avatar
DneprDave
I used 1/4" hydraulic hose to remote mount the oil pressure sender away from the engine.
any hydraulic shop will custom make a hose, it's not expensive.
Old Jun 13, 2018 | 07:16 AM
squawSkiBum's Avatar
squawSkiBum
Moderator
see here: https://www.northamericanmotoring.co...r-dummies.html
Old Jun 13, 2018 | 10:53 AM
drea-min's Avatar
drea-min
Oil pressure sender
I didn't realize cheaper $2.99 to use grease gun hose its made for high pressure, the fittings are standard thread 1/4"
Old Jun 13, 2018 | 12:37 PM
DneprDave's Avatar
DneprDave
Good idea. I needed two feet of hose to mount the sending unit where I wanted to and I was concerned with tolerance to heat in the engine bay. The hose I had made was less than ten dollars.
zoedragon
Jul 13, 2010 01:29 PM
FATBOY59
Dec 26, 2004 10:10 PM
mvalant
Apr 2, 2004 10:09 AM
perfpow
May 20, 2003 10:50 PM
laclede
May 2, 2003 05:37 AM
