New Byte Tronik Hidden Dash Cam
Old Jun 7, 2018 | 04:43 PM
  #26
Bytetronik's Avatar
Bytetronik
Originally Posted by chuckee98
So I finally got around to installling the mirror cam, and have been playing with it and trying to figure out how it all works, since the instructions are cryptic at best. Had a couple of questions, and hopefully someone can answer them for me...
What is the "urgent" folder and the "emergency videos"? I had three videos pop up as "emergency videos", and downloaded one, which ended up in the "urgent" folder. No clue what I did to tag these videos as " emergency". Also, how do you delete the "emergency video"? I can select the regular videos and delete those, but am not able to select any of the "emergency" ones.
Emergency Videos are saved in a separate folder as a result of your "Impact sensitivity setting". They are set aside so it doesn't get erased accidentally.
So if you hit a pot hole at high rated speed, the shock sensor inside the camera triggers an "incident" and saves the current video in the "emergency videos" folder.
Old Jun 7, 2018 | 06:29 PM
  #27
chuckee98's Avatar
chuckee98
Hey, thanks for the explanation. I kinda assumed that, but in all the "emergency" videos the car wasn't moving. From what I gathered, it might be triggered by my passenger closing their door. I've been playing with the impact settings to see which is the best for my scenario.
In regards to deleting the videos, I found that reformatting the card using the app will erase them, or manually deleting them from the card by using my laptop.
Appreciate the help.
Old Aug 27, 2019 | 09:32 PM
  #28
OSilvera's Avatar
OSilvera
Installed the R56 version in my 2016 Countryman S R60
Looks great, totally stock, I haven't wired it yet, but I will tomorrow and report. Only issue is, when I scanned the QR code the app is completely in Japanese. Does anyone have the English version of the app?... Android please...
Oh, PS. I saw a youtube video of this unit installed in a Countryman with the Rain sensor like mine and the top of the frame is blocked, but it's suck a wide image that it's still plenty of view. The rain sensor kind of acts like a sunshade to keep flares at bay.
here is the vide I saw that shows the cameras for the R60.
Old Aug 28, 2019 | 07:49 AM
  #29
d2mini's Avatar
d2mini
So nothing for F60 Countryman?
Old Aug 28, 2019 | 07:43 PM
  #30
OSilvera's Avatar
OSilvera
Hi folks.. I purchased a dashcam from Bytetronik in Tx. It's their R56 version, Looks super OEM, Very easy to install. Has an App you can download for both Android or Iphone to control. The camera comes with wiring that allows you to plug it's connector directly into your OBD2 port it you run the camera wires down the drivers side, or you can wire it down the passenger side and use an Add a Circuit fuse holder in the kickpanel on the passenger side.
The kit wires with Ground, Acc power, and constant power.. On my 2016 Countryman S, I wired the ACC wire to Fuse 44, then the Constant 12+ wire to Fuse 7. and the ground I wired to a large 13mm bolt on the passenger dash side. You see access to the bolt when you remove the glovebox.
Old Jul 28, 2021 | 11:18 AM
  #31
Agbullet25's Avatar
Agbullet25
Sure would be nice if the distributor could respond to messages on whether this will become available again or is still available.
Old Jul 31, 2021 | 07:06 AM
  #32
Bytetronik's Avatar
Bytetronik
These have been discontinued.
Old Dec 20, 2023 | 03:58 PM
  #33
wkearney99's Avatar
wkearney99
Does anyone know if the R56 unit would also fit the R57 convertible? There are various aliexpress providers with cameras that seem like they'd fit, but I don't know how different the R56 mirror is from the R57 convertible. This being a basic setup, not with any rain sensor on the glass, just a stalk down from the trim around the window.
R57 convertible rear view mirror mount
VelvetFoot
Jan 9, 2021 01:05 AM
engel
Electrical
Jan 23, 2016 08:34 AM
honderpilot
Oct 27, 2015 04:03 PM
Mini///M
Electrical
Nov 18, 2013 11:53 AM
TulsaMINI
MINI Camera and Video
Dec 5, 2006 04:07 PM
