ERROR p0015 PLEASE HELP
Old Jan 28, 2016 | 12:37 AM
Luca Buassi's Avatar
Luca Buassi
Hello everyone!
i know that the P0015 error issue has been discussed already but I'm getting totally crazy!
i replaced both camshaft sensor and vanos solenoid but the error still there not matter what!
does anyone had or have the same issue??
does someone know what should i do next to get it fixed??
i noticed that when i start the engine the rpm goes up for like second to 2.5 and then comes back down to 1.2 while the engine is heating up.
then i drive for like few miles and the check engine light comes up again..
also i noticed that when the engine is a normal temperature and i try to shut it down and turn it on few times the check engine light goes away and then after like 10 miles comes back...
please if anyone had this issue fixed please let me know what i should do..
thankkkssssss
Old Jan 28, 2016 | 09:22 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
First, what MINI do you have? Poor idling is definitely a symptom of P0015. It could ultimately be a timing issue. Check out this thread HERE.
888.280.7799 | 6am - 5pm PST
Old Jan 28, 2016 | 10:10 AM
Luca Buassi
I have a 2007 mini cooper (not S)
Old Jan 28, 2016 | 10:22 AM
PelicanParts.com
Vendor
Ok, so that link I posted above is still a viable option as it was a timing issue with his Non S N12 engine. If you're DIY savvy you will want to check your chain as your timing could be off. We have timing parts here if needed.
Old Feb 4, 2016 | 06:01 AM
Best info is here for the Cooper ( NON S ) N12 engine:
https://www.northamericanmotoring.co...th-my-car.html
ctrlaltdl
Jan 14, 2016 07:48 AM
Paul Yan
Jan 6, 2016 09:05 AM
dhessel
Jan 5, 2016 10:58 AM
dhessel
Jan 3, 2016 11:22 AM
sevin
Dec 31, 2015 10:19 PM
