Cold Exterior Trim Blackout
Old Jan 9, 2016 | 04:15 PM
Promius's Avatar
Promius
Hey guys
I want to black out my exterior trim (headlight rings, tail lights, grille ring, door handles, gas door, side light chrome) and I dont want to wait till Spring to do so. Would Plasti Dip spray be ok to use in the cold weather? (NYC area, 30s/40s right now). Sadly I dont have a garage to do this.
G
Old Jan 10, 2016 | 08:12 AM
MiniRoadstah's Avatar
MiniRoadstah
Like most paints, 50 degrees or higher is best. Lots of Youtubes DIY tips on Plasti Dip. I would do the research first.
Old Jan 11, 2016 | 10:34 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
I think that might be too cold as you may not get an ideal outcome. Some info here.
888.280.7799 | 6am - 5pm PST
Old Jan 11, 2016 | 11:01 AM
Originally Posted by Promius
Hey guys
G
I would not do it when cold, if you have access to take the parts off and bring them into a warm spot or garage is ideal.
Old Jan 11, 2016 | 02:07 PM
Loyal242's Avatar
Loyal242
Hey guys
G
If you don't have access to a garage then I would wait for warmer temps to do some plasti-dipping.
IIRC the minimum recommended temperature is 65*.
My garage is not heated, but I have done some dipping in there in January. I used a space heater to warm it up as much as possible - to around 60* - and my projects turned out fine.
Old Jan 11, 2016 | 05:54 PM
Promius's Avatar
Promius
Thanks guys I'll wait it out.
Old Jan 21, 2016 | 04:26 AM
r7denz's Avatar
r7denz
Also, I don't think plastidip is good on door handles, however anything that you wont touch on a regular basis should be fine and last longer.
Old Jan 21, 2016 | 12:57 PM
Welcome. Much better results in the warm.
Red Raven
Jan 4, 2016 07:16 AM
overs001
14
Dec 21, 2015 11:30 AM
moonloop
Dec 14, 2015 10:52 AM
Hendricksen
Dec 13, 2015 06:32 PM
jwreichle
Suspension
Dec 12, 2015 08:31 PM
