Schroth Quick Fit Pro in R53 GP
Old Dec 12, 2015 | 08:36 PM
rob76turbo's Avatar
rob76turbo
Hi Everyone,
Has anyone installed the Schroth Quick Fit Pro in a 2006 GP? I am looking for install pix to determine what I need to do to install them.
Any help or direction to an existing thread / link would be appreciated.
Thanks!
Old Dec 13, 2015 | 05:00 AM
bavmotors's Avatar
bavmotors
Is that possible since there's no rear seats?
Old Dec 13, 2015 | 07:49 AM
rob76turbo's Avatar
rob76turbo
BAVAUTO, I have seen pix of the harnesses installed. Just not detailed installation process pix. Was hoping to find some of those. From what I understand I need to buy the rear / center seatbelt receivers and will need to locate the outboard seatbelt anchor position. It will require some fitting, but I will most likely buy back up pieces so that I can return to stock.
Old Dec 13, 2015 | 01:39 PM
bavmotors's Avatar
bavmotors
You could go to a junk yard and get the measurements for the rear seatbelt attachment points and the necessary hardware then I think you would be all set.
Old Dec 14, 2015 | 07:31 AM
quikmni's Avatar
quikmni
I just use the CG-Lock in the GP rather than adding the extra seat belt hardware. Works OK but of course not as good as a Harness.
Old Dec 14, 2015 | 08:06 AM
More info here:
https://www.northamericanmotoring.co...ml#post1473899
https://www.northamericanmotoring.co...lts-on-gp.html
http://www.gpmini.net/wp/2007/04/harnessing_the_gp/
JamesDeBart
Feb 10, 2016 07:13 AM
Willcoop
Dec 29, 2015 11:03 AM
zakindi
Dec 16, 2015 11:45 AM
Codypantz
Dec 10, 2015 08:48 AM
USA-RET
Dec 9, 2015 12:26 PM
