Trackday/Autocross/Hillclimb setup and talk
Old Jan 23, 2015 | 12:19 AM
yukinoinu's Avatar
yukinoinu
So I will be driving down to Williams,CA for a Trackday, and then come back to Washington for many autocross and hill climb events. Anyone have a nice setup for Trackdays/Autocross/Hillclimb? What you recommend and don't? Needed vs luxury? any plans? Things to do before each event and how to practice? My major thing will be autocross for sure, I don't know how I would prep for this or a race without breaking laws.
Old Jan 23, 2015 | 02:57 AM
Rustyman311's Avatar
Rustyman311
Do you have a rear sway bar setup? And if I'm not mistaken that SC pulley already moves you out of stock/street class....possibly puts you in a prepared or modified class via Autox. If that's the case put the biggest comp bar in the rear with drop links. Also look at a nice set of Hooisers or Hankook R comp tires, running in prepared/modified classes is difficult without them...are you running up graded brakes too?
Old Jan 23, 2015 | 03:30 AM
yukinoinu's Avatar
yukinoinu
No rear sway... yet. upgraded pads, rotars, and steel lines. unfortunately not big brake kit as for the autox most likely I will be running against GT-Rs, Ferraris, Porches, Lamborghinis... don't think I'll be top dog xD Damn rich people here xD
Old Jan 23, 2015 | 04:56 AM
Saltysalt's Avatar
Saltysalt
you need to see whats available for you class for modifications. then you go from there.
IF there are no classes the list is nearly endless
Old Jan 23, 2015 | 08:40 AM
ZippyNH's Avatar
ZippyNH
Just have fun...
As a "newbie" with a first time car and a limited budget, I doubt you can be competive by spending a few $$...
So my suggestion...
Flush your brake fluid, make sure all your basic systems are good (cooling system, recent oil change before AND after, etc)...
Consider this event to be about learning, fun and education....know your limits. A bigger rear sway bar IS a great plus for any mini, street or track, but it does take a bit if skill to use safely, and making a change right before an event without a driver education event, like an auto-x, to learn how to handle it might be a bit dangerous...thinking the hill climb here ..
Longer term, good tires, and bigger rear sway bar is a great start....and as you gain skill, you can make changes as you find individual items limit you.
Old Jan 23, 2015 | 09:40 AM
Rustyman311
What pads are you running? As far as lambo's and such it's all about the driver....you may have a quarter million dollar car but if you're out there getting your *** handed to you by a crx...it proves a point very quickly hahaha.
Figure out where your car will class then go from there. Run the car for a couple events as is then make your changes...
Old Jan 23, 2015 | 09:52 AM
Slave to Felines's Avatar
Slave to Felines
I totally agree with these guys. Just make sure the car is in top working order. I suggest fresh brake fluid; I cooked six-month-old fluid in my "other car" and had a few "pucker moments" my first track day.
Go through your car's interior thoroughly, and pick up all of the junk that accumulates in areas you don't usually see or think about. Like under the seats. I had a student who had a quart bottle of oil slide out from under the seat and into his pedals. That was not a good recipe for car control. Get yourself one of those plastic boxes you can get from Wally World or Target, and put everything that isn't inside of a closed compartment into there.
Make sure you bring water, sunscreen, and food if you don't want greasy fried burgers or similar--if those are even available. And rain gear. You're going to be out in the weather for a while, so make sure you're equipped to deal with that. (This is more true for autoX.)
Then go and have fun! Concentrate on driving and learning, and forget modifying the car for a while.
Old Jan 23, 2015 | 11:04 AM
hsautocrosser's Avatar
hsautocrosser
The best resources you are ever going to find for answering those questions are the people at the events you are going to participate in. Here's their on-line starting point:
http://www.nwr-scca.org/solo/Start.htm
Old Jan 23, 2015 | 12:31 PM
yukinoinu's Avatar
yukinoinu
Thanks everyone! I will be recording all my races,auto and hillclimbs with a gopro in i guess 3rd person driver view? you will be able to see what gear, pedal use speed and of course the track! I will also try to do a roof mounted view of the events too if permitted.
Old Jan 23, 2015 | 01:54 PM
kyoo's Avatar
kyoo
tires! good luck!
IQRaceworks
53
Jun 28, 2024 07:29 AM
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
minimofo
Dec 26, 2015 12:03 PM
Suspension Products
Oct 1, 2015 11:53 AM
