Quick question - OBDII reader options
Old Feb 27, 2014 | 04:58 AM
samteezy's Avatar
samteezy
Hey all,
I'm trying to decide on a OBDII reader for my Clubman.
The top choice seems to be the ScangaugeII but $160 seems to be the lowest it can be found at anywhere.
Alternatively, the Kiwi 2 Bluetooth seems like a viable alternative for me (I'm an Android user) and it retails for nearly half the cost at $90.
Does anyone have experience comparing the former and latter? Does it make more sense to have the connective flexibility of the Kiwi 2 or the dedicated screen on the Scangauge?
Old Feb 27, 2014 | 06:13 AM
richardsperry's Avatar
richardsperry
It is a choice... I chose the SC2 and the Craven Speed mount. I don't want to have to be dicking with my phone every time I get in the car. The SC shows me intake temp, boost, water temp, and volts all the time, with a bunch of other stuff if I care to pull it up. The color matches the MINI pretty well, and I don't have to remember to take it out all the time.
Old Feb 27, 2014 | 06:50 AM
rckrzy1's Avatar
rckrzy1
dashcommand and obd2 to wifi cost me $30 total, shows every thing and reads codes and deletes normal codes.
Old Feb 27, 2014 | 08:50 AM
minirab's Avatar
minirab
I concur.
Old Feb 27, 2014 | 09:39 AM
AZdsrt's Avatar
AZdsrt
I use a bluetooth ODB (bought on ebay for $20), and the Torque app for Android ($5). Works pretty good, though means you have to futz with the phone..
Old Feb 27, 2014 | 06:02 PM
05r50's Avatar
05r50
I have the ScanGauge. It works fine. I also use Torque with my Android and a bluetooth adapter. It works fine on the MINI but doesn't work on my RAM hemi.
I also have one of these if you are just wanting to read codes. http://amzn.com/B001LHXTO0
Old Feb 27, 2014 | 06:06 PM
c0op3r's Avatar
c0op3r
I was using a no name ELM327 WiFi (I use iPhone) with DashCommand.
I just the other day switched to Kiwi² with the Analog interface so that I can have AFR readings, and I will soon be adding the Exhaust Temperature analog.
I do not think that the scan gauge does analog interfaces.
Old Feb 27, 2014 | 09:19 PM
6thGear's Avatar
6thGear
couldnt have said it better myself.....I really like the real-time gauges.
Originally Posted by minirab
I concur.
Old Feb 28, 2014 | 09:52 AM
Slave to Felines's Avatar
Slave to Felines
Originally Posted by c0op3r
I just the other day switched to Kiwi² with the Analog interface ...
What is the Analog interface? Does it do more than just plug into the OBD2 port?
Old Feb 28, 2014 | 11:02 AM
c0op3r's Avatar
c0op3r
Yes you can add real gauges sensors that read out on the OBDII software, I added a WideBand O² sensor and am going to add an Exhaust Gas Temp sensor.
http://www.plxdevices.com/product_cat.php?id=SEMO
W0TM8
Dec 19, 2019 07:50 AM
mini yellow-haa!
Aug 13, 2015 11:18 AM
nomar116
Aug 10, 2015 11:24 PM
papawhiskey
Aug 10, 2015 09:31 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
