c02 sensor
Old Jul 5, 2013 | 04:46 PM
pledroit's Avatar
pledroit
c02 sensor
does it really need to be replaced
Old Jul 5, 2013 | 04:51 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Philosophically or is this a trick question....
Old Jul 5, 2013 | 04:56 PM
pledroit's Avatar
pledroit
c02 sensor
seriously. the mechanic was not certain
Old Jul 5, 2013 | 05:13 PM
-=gRaY rAvEn=-
Moderator
Any more info on your MINI since you posted this question in the wrong area of our forum ?
Did your mechanic mention a code ?
Old Jul 5, 2013 | 05:16 PM
pledroit's Avatar
pledroit
02 sensor
no he just said the reason for the engine light coming on was the c02 sensor
Old Jul 5, 2013 | 05:36 PM
Porthos's Avatar
Porthos
CO2 or O2? Because I have never heard of a CO2 sensor.
Old Jul 5, 2013 | 05:38 PM
jordan.burks's Avatar
jordan.burks
if its the O2 sensor the owners manual on my 07 MCS said to replace them every 120,000 miles.
Old Jul 5, 2013 | 05:39 PM
-=gRaY rAvEn=-
Moderator
Depending on your build, there is an extended warranty for some 02 sensors....you really need to post up more info to get the help you seek.
Old Jul 5, 2013 | 06:38 PM
ZippyNH's Avatar
ZippyNH
And WHICH o2 sensor....
The post cat...which monitors the cat and its efficiency or the upstream o2, which the motor uses to monitor the fuel/air mixture.....
Old Jul 8, 2013 | 05:41 AM
ignitionmodule's Avatar
ignitionmodule
Unless you have contaminated your sensor with leaded gas or silicon, the 120,000 mile interval should be the only normal reason to replace your sensor. That being said, one does ocaissionally fail usually from thermal shock (water splash on the sensor after the heater starts) or a sealing failure at the wire exit side.
shorenetworks
Nov 4, 2019 06:18 PM
CRC
Dec 26, 2015 11:30 AM
sempaipaul
Sep 18, 2015 03:05 PM
Doc Pain
Sep 15, 2015 11:31 PM
Sep 14, 2015 12:48 PM
