New Clutch - Which One / How Much?
Old Mar 20, 2013 | 06:54 PM
SoundMessage's Avatar
SoundMessage
So, based on my findings and recent worsening symptoms, it looks like I'll be replacing the clutch in my 09 MINI Clubman S.
The dealership just quoted me $2500 to replace the clutch, $3500 if I need a new flywheel as well.
Questions:
1) Does anyone recommend an alternative clutch to the one MINI would replace it with? If so, which one?
2) Am I really looking at a $2500-3500 bill? Or, should I be able to do this for less money?
Thanks for your help and advice on this one. I really need to learn how to do this stuff myself but wouldn't have any idea where to start.
Old Mar 20, 2013 | 06:56 PM
SoundMessage
P.S. I guess I should've purchased the MINI Extended Maintenance program. :( I suppose it is too late now that I have this issue.
Old Mar 20, 2013 | 07:01 PM
IzzyG's Avatar
IzzyG
Get a quote from an independent shop. I've seen some posters stating that they got it done for about 1600 with the flywheel. Swapping the clutch and flywheel seem rather daunting for a DIY but there's definitely tutorials if you're feeling up to it. I have done plenty of mods myself and work on the car often. However, when my clutch goes out , I'm paying someone :/ Unless I have an experienced mechanic to show me every step.
Old Mar 20, 2013 | 08:35 PM
NJ Mini's Avatar
NJ Mini
OS Giken seems to be the aftermarket clutch of choice. Cheaper and stronger. I'd look for an independent shop to do the work on this given MINIs labor rates.
The extended maintenance usually has to be purchased before the included maintenance plan runs out at 3 yrs/ 36k miles.
Old Mar 20, 2013 | 09:35 PM
SoundMessage
OS Giken at WMW is $1789. That's cheaper than OEM? Or, am I not looking at the right thing?? Any other recs?
Old Mar 20, 2013 | 09:42 PM
Soup's Avatar
Soup
OR you can just buy the parts and do it yourself, its truly not that hard.
Just do some research and anyone should be abe to figure it out. Hardest tool you need is a torque wrench and thats good to own anyway. Save yourself $2000
Old Mar 20, 2013 | 09:47 PM
SoundMessage
I would LOVE to learn how to do this, but I feel like I would need handholding along the way...i.e., have a mechanic there to show me. I also do not have a lift, tools, etc.
Old Mar 20, 2013 | 10:01 PM
ZippyNH's Avatar
ZippyNH
the parts cost on a clutch job is the cheap part....
the FULL day labor to do it is the killer....check for a MINI friendly independant shop....best way to save BIG $$
The OEM is the best for 90+% of folks...even modded.
Old Mar 20, 2013 | 10:03 PM
Soup's Avatar
Soup
Thats how I felt about my other car, but I just researched a ton, and had a buddy that has done it before (offer free Beer always helps ) help out.
I dont feel like you need a lift, I believe it makes certain aspects a lot easier.
But its always scary tearing into your own car doing something new.
back on subject, I personally believe a aftermarket product (quality product) is better than OEM. Dealer mechanics are going to tell you your wrong.....dealer mechanics are idiots and from experience generally can make issues worse.
First and only time a dealer has ever touched one of my cars happen to be the mini for the powersteering rack. After install I now have a wierd random rattling vibration I cannot find then found all the fancy blue painters tape left inside the engine bay marking things.
Do some research find a good aftermarket stockish clutch and a shop (usually one that specializes in performance based applications...no brake or muffler shops etc) to install it. Your still gonna pay some coin, but not $2500 bucks. Hell google it and youll be able to find a OEM clutch cheaper than they offered you.
Old Mar 20, 2013 | 10:20 PM
SoundMessage
I guess I was hoping to find a more "durable" clutch than OEM, if one exists.
Old Mar 20, 2013 | 10:35 PM
ZippyNH's Avatar
ZippyNH
Only one that MIGHT fit that requirement is the OS Gilken....but a BIG +$$$.
Issue is ANY aftermarket clutch you see that CLAIMS more holding power does this with a softer, better grabbing (aka- faster wearing) clutch media..so shorter life....and a bit loss of drivability. If you have ever driven a car with a high performance clutch in traffic, you would remember it!!
Generally a harder pedal, and most are FULL ON or OFF.... generally not what most folks want on a dailydriver. THEN add shorter life.....
Old Mar 20, 2013 | 11:16 PM
SoundMessage
Thanks. Yeah...if the aftermarket choice is the $1800 OS, then I'm probably going to stick with OEM.
Is this everything I need, parts-wise?
http://www.pelicanparts.com/cgi-bin/...7-572-843-M262
http://www.pelicanparts.com/cgi-bin/...-7-575-069-M38
Old Mar 21, 2013 | 05:48 AM
So how many miles did you have on your Clubman when they said you needed a clutch ?
If you are looking for options, most of the time the stock clutch for replacement is good like mentioned above. I have had a MINI first gen clutch last well over 120,000 miles. It was the throw out bearing that was the problem, making noise of course.
You could go with the OEM Genuine MINI clutch kit and Flywheel in Sachs. I have replaced the guide tube on these also due to the rubbing and wear from the throw-out bearing. Also make sure you check the seal behind the guide tube and make sure there is no seepage. I have seen this in the past.
Link to your 2009 MINI Clubman S:
http://www.ecstuning.com/Mini-2009-Cooper-R55-S_Clubman-Coupe-L4_1.6L_N14B16A/Drivetrain/Clutch/
Thanks and let me know if you need anything else. I hope you can get things back together soon. When I had a clutch out with the MINI on the rack, it does make you miss your car.
Old Mar 21, 2013 | 07:36 AM
Helix13mini's Avatar
Helix13mini
For reference, we charge $850 labor flat rate for a clutch swap and $170 more to do a diff.
Old Mar 21, 2013 | 09:56 AM
SoundMessage
I've got 52K on the car. I'm the 2nd owner from 40K, so I have no idea how the first owner drove it. Although, I can tell you the clutch pedal required an adjustment when I purchased the car to remove a "clicking" sensation when pressing it.
I know the clutch is slipping badly, but I do not know the exact cause. I'm just assuming the worst case scenario. The thing is that I don't want to waste a few hundred $$ in diagnostic fees. How do I have a shop tear down the car, tell me what's wrong, and then wait for the parts to come in? I feel like I need to have the parts in hand first. Or, am I wrong about this?
If nothing else, I need to plan the proper amount to budget for the worst case scenario.
Old Mar 21, 2013 | 09:59 AM
SoundMessage
Thank you. I'd be very happy if I could find a good shop to do this for $850. I need to call around today for some quotes.
Old Mar 21, 2013 | 10:06 AM
Creeve's Avatar
Creeve
I just had my clutch and flywheel replaced at an independent shop.
Cost-
Parts - $1200 (OEM $850 flywheel and $350 clutch)
Labor - $900
Total - $2100 + tax
I also had all the seals and the slave cylinder replaced, but thats not necessary.
Old Mar 21, 2013 | 12:03 PM
SoundMessage
Best quote I've received so far is:
$1000 labour
$1400 parts (about $500 clutch, $900 flywheel (rounding))
This shop is willing to install parts I provide, but if there are any problems with the parts, will charge me labour again to fix vs not if problems arise with parts they provide.
I can get the clutch and flywheel for $942.30 shipped from ECS.
What would you do?
Old Mar 21, 2013 | 12:16 PM
If you are getting all the parts SoundMessage, get the guide tube and the seal behind the guide tube. That way you don't take everything apart then find out you need more parts.
Old Mar 21, 2013 | 12:30 PM
ZippyNH's Avatar
ZippyNH
The prices you see here should not be THAT far off from the parts cost the shops can get wholesale PLUS their "customary" markup.....
So to save maybe $100 or so on parts, you loose the warranty on the shop-work....
(Guess you could do a bit of a hybrid deal, and say you will supply the clutch+flywheel, and they do the "extras" like guide tubes, etc....)
I would ask the shop pretty bluntly if they have ever done a MINI clutch..then the year of the car (gen1 vs gen2)...the learning curve is pretty steep.
From the Price of the labor they quote, I just worry they might be thinking they will come out ahead, even if it takes a bit to 'LEARN' on your car....
Call any BMW shops?...they sometimes do a bit of MINI work....maybe get a "better quote".
Old Mar 21, 2013 | 12:53 PM
SoundMessage
The shops I called are the two independent MINI shops here in Las Vegas (although one of these shops isn't much cheaper than the dealer, sometimes). Both come consistently recommended by the local MINI club. I'll double check specifically on the clutch though. Thanks!
Old Mar 21, 2013 | 01:15 PM
ZippyNH's Avatar
ZippyNH
If they are both MINI shops, I would not worry.....They have likely done a boatload!! I just wanted to be sure it was not a local "guy" who does work on cars....
Labor rates vary soooo much, it is hard to guess, but it seems reasonable.
good luck, and know this one SHOULD last longer......
Somebody likely slipped it a bit in the past...either inadvertently or on purpose....or did lots of stop and go driving!!
Old Mar 21, 2013 | 02:22 PM
SoundMessage
Previous owner was in the Los Angeles area, so I bet the stop and go driving is for certain.
Old Mar 21, 2013 | 02:23 PM
gkp's Avatar
gkp
I just had the OS Giken put in. Under $3k total for parts, labor and tax. It's a single plate, so it is noisy and not as street-friendly as the OEM, but I track the car so it is what I was looking for.
Old Apr 12, 2013 | 05:22 PM
SoundMessage
Finally should be able to pay for this repair next week. I spoke with the shop, and they agreed to order and back the Sachs flywheel for me, which saves me a couple hundred $$ over the OEM one. So, I'm getting the Valeo clutch kit, Sachs flywheel, and the guide tube/seal done for $2200, including tax, etc.
