2005 MINI Cooper slips in first gear
Old Mar 13, 2013 | 09:56 AM
SafetyMoose's Avatar
SafetyMoose
So my friend has a 2005 MINI cooper slips in first gear when he was driving. He said he has an AVT Transmission, I thought all minis have the CVT transmission and when I talked to my transmission friends they say its expensive to repair because BMW doesnt want to fork over the parts for cheap so its best to get it from a wrech. What do you think the issue there is?
Old Mar 13, 2013 | 10:13 AM
martinb's Avatar
martinb
Likely your friend meant CVT. However, I'm not sure the CVT was even available in 2005. At some point the CVT was dropped. 'Likely someone else will know for sure.
The Mini CVT doesn't have the best reputation. And the best way to take care of the problem is to find a functioning used transmission, put it in, and then sell the darn car. I like the CVT in our Nissan Murano. I wouldn't have on in a Mini. (Even Mini doesn't install them anymore.)
If anyone plans on keeping their CVT, change the transmission fluid MUCH more often than the factory recommends and use the very, very best fluid available. Then change it more often.
Did I mention that it must be changed far more often than recommended?..............
Old Mar 13, 2013 | 10:24 AM
SafetyMoose
HUH? So wait what type of tranny is in the 2005 MINI if its not the CVT? My friend was quoted 5k to repair it and 11000 to replace by BMW.
Old Mar 13, 2013 | 10:27 AM
ZippyNH's Avatar
ZippyNH
A cvt does not have "gears", but the computer is programmed to simulate gears to make folks feel more like it is working right, rather than just a constant rpm buzz....
The cvt tranny is a metal belt and two pulleys....not particully well understood, limited parts from the orgional maker, and a very poor/bad reputation.....regular fluid changes help the life a bit, but a very $$ fix...non dealers sometimes can fix them...but it is NOT a sure thing.
Old Mar 13, 2013 | 10:28 AM
ZippyNH's Avatar
ZippyNH
Check the motoringfile buyers guide...has the year by year changes for the mini...
Old Mar 13, 2013 | 10:57 AM
martinb's Avatar
martinb
Not sure. All I know is that Mini stopped using the CVT trasmission and went to a more conventional automatic at some point in the 1st gen life span. I know that the 06 automatics were not CVT. And I'm guessing that the 05's might not have been as well. You'll have to check into it.
Either way, if the transmission is shot, a good unit out of a wrecked car is likely your best option. And if it turns out to be a CVT equiped car, I'd sell it as soon as it's repaired and let someone else take the risk that it will fail again.
Old Mar 13, 2013 | 11:05 AM
ZippyNH's Avatar
ZippyNH
http://www.motoringfile.com/mini-r50r53-buyers-guide/
The MC also had similar tweaks that resulted in slightly more torque and better power power throughout the range. However the biggest change to the drivetrain of the Cooper was the introduction of the Getrag 5-speed gearbox in place of the problem prone and rather ancient Midlands manual unit. The new gearbox produced better feel and real feedback – a big step up indeed.
Another option introduced in the 2005 model year MCS (starting with 01.05 builds) was the much debated Aisin 6-speed automatic gearbox. The gearbox offered mediocre performance (almost a full second slower than manual cars) but allowed for easy operation in heavy traffic. It also featured paddle shifters that allowed for a semi-manual option. In the real world however, the computer still would over-rule this manual control from time to time. While it was a welcome option for some, it was derided by most in the MINI community as pandering to the US market. Yet that didn’t stop as many as 50% of soon to be MINI owners from checking the “auto” box on the ordering sheet...............
.........Another area that problems persisted were with the One and Cooper models with the optional CVT transmission. While issues seem to be less frequent than the earlier cars, the basic design of the transmission didn’t change in ’05 and thus it would be wise to keep this in mind when shopping. Of course the newly released automatic on the Cooper S was a traditional torque converter style auto that doesn’t share any of the CVT issues. That said modern automatic transmissions aren’t always known for their long-term (100k+) reliability so keep that in mind.
Old Mar 13, 2013 | 12:25 PM
SafetyMoose
would you be able to replace a CVT with an AISIN and is it cheaper?
Old Mar 13, 2013 | 12:39 PM
ZippyNH's Avatar
ZippyNH
Nope.
Too integrated into the computer....and the PHYSICAL location of the motor is SLIGHT different in the S auto..over about an inch, and slightly higher...and the gearing would be off....
http://www.waymotorworks.com/cvt-to-...rsion-kit.html
CVT to 6spd manual transmission conversion kit for R50 and R52 MINI Cooper non S with automatic trans. If you have a dead CVT trans and don't want to spend the big bucks replacing it with another junk CVT trans at $8000, this is a kit for you.
Kit inlucdes:
New Valeo Clutch, flywheel,throwout bearing kit
New 6spd trans cv axles
Used manual clutch/brake pedal assembly
Used clutch master cylinder
Used clutch lines
New clutch slave cylinder
Used shifter box and lever
You will still need a trans, shift cables, an aftermarket airbox, and Computer coding to make it all work.
Fits 2002-2006 Cooper R50
Fits 2005-2008 Cabrio R52
Details
SKU CVT26spdkit
Price: Call for current price
Not cheap either....and you need to get the car to GA, and you end up with a STICK!
Old Mar 13, 2013 | 01:11 PM
martinb's Avatar
martinb
So, it would seem that if your friend's Mini is a regular model, it's a CVT transmission. If it's an S model, it's the more conventional Aisin transmission. Either way, it's much less hassle to replace what's already in there. The only way it might be worth it to upgrade from the CVT to the Aisin would be if he's dropped a ton of money into the rest of the car and can't bear to part with it.
But either way, if it's really a CVT car, even after replacing the transmission, I'd sell it quick while it's still running.
I find it remarkable that roughly 95 percent of new car buyers buy an automatic.
iggi
18
Feb 9, 2026 01:00 AM
Accessory Products
Aug 10, 2015 01:35 PM
Aug 10, 2015 01:33 PM
Aug 7, 2015 07:12 AM
