Best Way to Spend $400-500 on Your MINI?
Old Feb 3, 2013 | 01:54 AM
SoundMessage's Avatar
SoundMessage
I'm finally getting rid of my run flat tyres on my Clubman, and I've got the detailing kit down. So, what's next?
Can anyone recommend something good on which to spend about $400-500 to upgrade/mod/treat my MINI??
Cheers.
Old Feb 3, 2013 | 02:00 AM
InVisib0L's Avatar
InVisib0L
I would have said get some Pilot Super Sports, but changing tires is already on your list.
Old Feb 3, 2013 | 06:06 AM
Nealuss's Avatar
Nealuss
I'm doing springs and a rear sway bar. That was in the 400-500 range for me, but I omitted a couple of things like rear control arms and end links. I figure I can do those without much hassle later on down the road.
Old Feb 3, 2013 | 06:31 AM
YZZX's Avatar
YZZX
Best $400 I have spent was Huper Optiks tint. Night and day difference in my driving comfort.
Old Feb 3, 2013 | 08:55 AM
Melangell's Avatar
Melangell
Sway bar.
Old Feb 3, 2013 | 08:57 AM
dannyhavok's Avatar
dannyhavok
Springs/Swaybar
Subwoofer
Tint
Old Feb 3, 2013 | 09:56 AM
Slave to Felines's Avatar
Slave to Felines
A couple of track days!!!
Old Feb 3, 2013 | 11:06 AM
SoundMessage
Got tint already.
What differences will I see with the springs/sway bar?
Any other ideas, or is this the consensus?
Old Feb 3, 2013 | 12:25 PM
kromdom's Avatar
kromdom
Originally Posted by SoundMessage
Got tint already.
In case you missed this thread: https://www.northamericanmotoring.co...rite-mods.html
Old Feb 3, 2013 | 07:40 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Welcome
The rear sway bar would be the biggest suspension bang for the buck mod you could do.
We also recommend the NM Torque arm bushing as a great cheap upgrade that you will actually notice.
Old Feb 3, 2013 | 08:52 PM
SoundMessage
Can anyone explain the differences in sway bars and offer a recommendation?
Old Feb 3, 2013 | 09:21 PM
RobMuntean's Avatar
RobMuntean
H-Sport Competition Bar. You don't want to go with a 19mm because you will likely regret it unless your plan on driving SUPER slow then go with the 19mm. I don't regret my competition bar, plus I have three settings which is nice
Old Feb 3, 2013 | 09:46 PM
Vindr's Avatar
Vindr
I have been looking for the best mod to do for this price range also. With the sway bar do you have to replace the endlinks? I know it would be best but will the factory ones last or will they go out quick?
Old Feb 3, 2013 | 09:49 PM
Vindr's Avatar
Vindr
Also should I look at lowering springs with sway bar or just a rear sway bar?
Old Feb 3, 2013 | 10:07 PM
RobMuntean's Avatar
RobMuntean
Originally Posted by Vindr
I have been looking for the best mod to do for this price range also. With the sway bar do you have to replace the endlinks? I know it would be best but will the factory ones last or will they go out quick? Also should I look at lowering springs with sway bar or just a rear sway bar?
You don't need the endlinks and control arms unless your lowering the car springs or coilovers. IMO, save for coilovers or Koni yellows with lowering springs. But the sway bar alone is good.
Old Feb 3, 2013 | 10:59 PM
kromdom's Avatar
kromdom
after searching/reading here, I went with a 22mm bar by ALTA:
http://www.outmotoring.com/mini-coop..._Sway_Bar.html
Old Feb 4, 2013 | 01:08 AM
MiniKar's Avatar
MiniKar
How about some nice aftermarket lightweight wheels, or interior LED's, or a nice detail job ???
Old Feb 4, 2013 | 07:58 AM
Porthos's Avatar
Porthos
Weight savings....its free.
Old Feb 4, 2013 | 08:12 AM
goldchild's Avatar
goldchild
bushing kit all around? maybe...
Old Feb 4, 2013 | 10:16 AM
condor27596's Avatar
condor27596
valentine one?
Old Feb 4, 2013 | 12:19 PM
bmwr606's Avatar
bmwr606
+1
the single mod that can improve lap times the most
if you don't believe me, check the lap times of F1 drivers vs civilians in the "reasonably priced car" on TOP GEAR
scott
Old Feb 4, 2013 | 06:59 PM
WayMotorWorks
Vendor
I too would suggest the Hsport Comp rear sway bar as it is the lightest available, has the best bushings, and zerk fittings on the mouts to regrease. Put it on in the Middle setting and enjoy.
Old Feb 6, 2013 | 05:26 AM
richardsperry's Avatar
richardsperry
#7. Seat time where you learn to drive your car. Unless you have lots of instruction under your belt, the car is way better than you are already. It will write checks your skill set can't cash.
Until you upgrade the driver, making lots of mods to the car just ensures that you are going faster when you crash...lol
Old Feb 6, 2013 | 06:02 AM
bmwr606's Avatar
bmwr606
richard
best description of what i believe!
scott
Old Feb 6, 2013 | 07:51 AM
davisflyer's Avatar
davisflyer
This makes NO sense at all...with 19mm set to full stiff, -2 deg front camber and -1.2 deg rear camber, car rotates very easily and is extremely fast....
