oil change
Old Dec 4, 2012 | 08:31 AM
frankgt's Avatar
frankgt
oil change
i have a 2012 MINI - non turbo - 1st time oil change.
what size wrench is needed for the oil plug?
thanks for the help.
Old Dec 4, 2012 | 09:04 AM
MarinePMI's Avatar
MarinePMI
I believe it's 36 or 37mm...
Old Dec 4, 2012 | 09:06 AM
pmsummer's Avatar
pmsummer
Is there a reason you aren't letting the dealer do it?
Old Dec 4, 2012 | 09:30 AM
frankgt's Avatar
frankgt
The nearest dealer is 3 hrs away. It has 11K mi - I'm old school and have no problem doing it myself.
Old Dec 4, 2012 | 09:50 AM
pmsummer's Avatar
pmsummer
I hear you. I change mine at 6K (well, I let the dealer do it because for $69, because the money I might save is more than offset by the disposal hassle... and it's only an hour drive to the dealer).
But I would SERIOUSLY recommend you only use the MINI factory filter all through warranty period.
Old Dec 4, 2012 | 10:01 AM
frankgt's Avatar
frankgt
I bought a NAPA Gold Filter 7512 and 5qt Castrol Edge 5W/30. I'll check with the nearest MINI dealer to see if this is acceptable.
MarinePMI suggests 36mm - this size is for the oil filter.
I'm still looking for what wrench and size is needed for the oil pan plug.
Thanks for responding.
Old Dec 4, 2012 | 10:24 AM
phoxx47's Avatar
phoxx47
The oil drain plug on the 2nd gen is 8mm Allen. For the filter I find a 1 1/16" six-point socket works great. The filter housing is plastic so do not overtighten when re-installing.
I believe the 36mm is the size for the first generation cars filter - not sure.
Old Dec 4, 2012 | 10:31 AM
pmsummer's Avatar
pmsummer
27mm for 2nd gen filter removal, is what I read (even though I bought a 36mm for some reason... in case I ever buy a Gen 1 MINI, I suppose).
Old Dec 4, 2012 | 10:41 AM
frankgt's Avatar
frankgt
8mm - thanks phoxx47. That's what I'm looking for.
Old Dec 4, 2012 | 11:19 AM
JoanieB's Avatar
JoanieB
Save your receipts and write your mileage on them, in case you ever have to prove that you did do the oil change.
Kimolaoha
Jul 5, 2023 01:04 PM
woodstudio
Mar 15, 2020 08:28 AM
Colt45Magnus
Jul 14, 2019 06:18 PM
patpatpat
Aug 27, 2015 07:51 AM
HaveATank
Aug 24, 2015 10:26 AM
