Body Shop Issues
Old Oct 15, 2012 | 09:25 AM
Highslot84's Avatar
Highslot84
Body Shop Issues
So I was rear ended in the middle of August. The body shop fixed everything and when I got my car back I needed the alignment done again because it wasn't correct. Steering wheel was still crooked. I took it back and they had to order a part and it's still not in as of today.. I have been driving the car because the Insurance Company stopped paying for a rental. Noticed this weekend the rear tires are bald.
Do I have a case to have these tires replaced? I believe that either the Body Shop or Insurance should pay for this because they were in very good shape before the accident and now they're trashed due to the alignment being off and not taken care of at a reasonable time frame.
Old Oct 16, 2012 | 06:23 AM
Klayfish's Avatar
Klayfish
What was damaged on the car in the accident? Will be hard to answer your question without knowing this. Was this a shop you chose, or an insurance company network shop?
Old Oct 16, 2012 | 06:29 AM
Highslot84's Avatar
Highslot84
I was rear ended on the right rear side. I chose this shop based on past experience with them. The alignment was part of the estimate.
Old Oct 16, 2012 | 06:42 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Does not sound like the alignment was done.
Call the insurance adjuster, take pics of the abnormal tire wear, calculate the mileage travelled since the MINI was returned to you. ( The body shop's repair order has mileage in )
Old Oct 16, 2012 | 06:51 AM
slinger688's Avatar
slinger688
What part was it you need? And what were the alignment specs you current have after the first alignment?
Sounds like two things, steering wheel crooked which is a front alignment and rear tire wear. That is why I am asking about why part it is.
Old Oct 16, 2012 | 07:42 AM
Klayfish's Avatar
Klayfish
That's something you'll need to go back to the body shop for. If an alignment was on the estimate, then the shop should have done it. Not sure if the original estimate had suspension repairs on it. Either way, the shop is responsible to expose and repair all damages. If they find additional damages not already on the repair estimate, then they should contact insurance. Otherwise, it's all up to them to correct....your tires included.
Old Oct 16, 2012 | 07:51 AM
Eric_Rowland's Avatar
Eric_Rowland
+1
Two different issues. OP says steering wheel was 'still crooked' - was it crooked before the accident? How many miles driven before the rear tires became bald? How much tread left previously? Even wear, or bald on the edges?
Old Oct 17, 2012 | 08:06 AM
Highslot84's Avatar
Highslot84
My steering wheel became crooked because the accident occured in a traffic circle, I was trying to continue to go around the circle to the left and the rear was pushed to the right. They needed the control arm according to the body shop.
The car is at the body shop now so we will see what they say.
Wohnson89
Jun 10, 2020 04:53 AM
Steeroidz
Aug 29, 2018 07:41 AM
Aug 21, 2015 02:29 PM
ASRman
Aug 13, 2015 09:33 AM
