Have a SC pulley question and more
Old Jun 4, 2012 | 07:00 PM
louprez's Avatar
louprez
Long story short I purchased a 06 MCS from a dealer auction and have no idea what mods came with it . I was able to find the original owner/enthusiast and to my surprise they are not being helpful at all . I was able to put it on a lift and found that I have the JCW exhaust and suspension . I do not know if this is the factory pulley and do not want to order one if it's not . Thanks for the help
Old Jun 4, 2012 | 07:12 PM
daflake's Avatar
daflake
That is not a factory pulley, it is a reduced pulley. Sadly we can't tell the size by just looking at it.
Old Jun 4, 2012 | 07:23 PM
louprez's Avatar
louprez
Thanks for the quick reply and I guess good news . I just have to find out what company or % .
Old Jun 4, 2012 | 07:48 PM
miniblucabrio's Avatar
miniblucabrio
the size should be stamped on the face of it. either 15% or 17%. could be a 19% but those aren't too common.
Old Jun 4, 2012 | 08:09 PM
louprez's Avatar
louprez
miniblu I did some internet surfing and I think its a minspeed pulley but they are out of business . I was having the mini get a complete maintenance and the tech threw out the belt so I am now trying to figure out % . This car is full of surprises so far can't wait to get it done .
Old Jun 12, 2012 | 06:39 PM
louprez's Avatar
louprez
bump
Old Jun 12, 2012 | 06:54 PM
ZippyNH's Avatar
ZippyNH
Originally Posted by louprez
bump
The question was answered....
why a bump?!
Old Jun 12, 2012 | 07:15 PM
louprez's Avatar
louprez
If anyone has a idea about the pulley
why a bump?!
Old Jun 13, 2012 | 02:43 AM
daflake's Avatar
daflake
What idea are you looking for? We can only tell you it isn't stock and the only thin you can do is get close to see if it is stamped with the size. Other that that, we can't tell you squat. Lots of vendors made pulleys like that.
Old Jun 13, 2012 | 04:15 AM
ZippyNH's Avatar
ZippyNH
And the vendor/make of the pulley does not really matter...
they are all, basicly, the same...slight differeances in attatchment methods or colors, but are all cnc machined metal....once installed, basicly the same...even the size varriation of the common ones, usually a 15%, newer tend to be 17%, and a slight chance of a 19...but thses were never common, troublefree or "mainstream".
Old Jun 13, 2012 | 07:11 AM
louprez's Avatar
louprez
thanks guys . I guess I am going to have to buy 2 belts and see which one fits then . Time to do some moding I guess .
Old Jun 13, 2012 | 08:00 AM
daflake's Avatar
daflake
Was nothing stamped on the face of the pulley?
You either need a 060532 or a 060535 belt depending on the pulley.
Old Jun 13, 2012 | 08:39 AM
ZippyNH's Avatar
ZippyNH
The 60535 belt will work fine for the 15% or the 17%...a few folks are starting to use the 532 length belt as a regular for the 17%....
Either way, change it every 2 years, or more often, and you are good to go!!
The stock belt uses metric sizing, is 1388 mm i think...a new on is ok with a 15%, but as it stretches, it will slip....the jcw is pretty much the same ...ok when new, but as it stretches with a smaller pulley, it will slip at higher rpms....so aftermarket belts in the previous posts are the most commonly used.
Old Jun 13, 2012 | 08:40 AM
BillyCuth's Avatar
BillyCuth
Maybe you can measure the diameter of the pulley to tell what % reduction it is? Just a guess I am throwing out there...
Old Jun 13, 2012 | 08:48 AM
ZippyNH's Avatar
ZippyNH
Not a bad idea...but it has been tried, and the numbers are not really useful...
The diameter to the edge vaires due to different designs and heights of the edge of the pulley that keeps the belt alighned....the actual diameter is from the groves where the belt rides....and few folks can measure down to the 1/2 mm needed to determine 15, 16, 17%, and even these numbers vary a bit by manufactures...
Older pullies tend to be 15%...if it is a minspeed (was a respected dealer in it day) it is most likely a 15%.....the 17% have become popular in the last 5 years....
Old Jun 13, 2012 | 08:56 AM
ZippyNH's Avatar
ZippyNH
as for other items your car may/may not have, if you go to a mini meet, another knowlegable owner can take a quick look and let you know what you have...
It is possible to post a few pics, but 1 or 2 minutes of hands on is very useful and much defenifitive.
Old Jun 13, 2012 | 10:25 AM
daflake's Avatar
daflake
To be honest, I use a 535 on my 17% and don't have a problem with slipping. So you are right, it should be fine.
alistaircookie
Oct 8, 2015 10:52 AM
maniacalmorgan
Aug 19, 2015 08:44 AM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
