License Plate Rattle
Old Jul 22, 2011 | 02:35 PM
JeremyB's Avatar
JeremyB
Does anyone else have a problem with their license plate rattling and it gets extremely annoying? I have a GP and there are only two top screws to mount the rear license plate to the back of the car. This causes the bottom side of the plate to rattle against my rear hatch causing a rather annoying noise. Anyone have a solution?
Old Jul 25, 2011 | 08:36 AM
e46jb's Avatar
e46jb
2 sided tape is one solution
Old Jul 25, 2011 | 08:46 AM
ZippyNH's Avatar
ZippyNH
Or tape/glue a rubber block (like an eraseor to the back of the plate or the car...be creative...be a mini driver!! Fashion something orgional!!
dannyhavok's Avatar
dannyhavok
+1, mine is never going anywhere.
Old Jul 25, 2011 | 10:30 AM
rustyeuro's Avatar
rustyeuro
mine has top and bottom spots for screws (plate frame of sorts) but i put 3m foam tape on there. it's about 1/8" thick made of weather stripping.
edit: stuck to the plate of course
Old Jul 25, 2011 | 11:06 AM
Porthos's Avatar
Porthos
I just got the screws for the bottom of the plate and screwed it in. Haven't had a problem since. Just to ask do you have a plate cover? You know the own that goes around the edge of the plate. If so, you might want to secure that too.
Old Jul 25, 2011 | 12:34 PM
TrueEddie's Avatar
TrueEddie
+1
Old Jul 25, 2011 | 12:39 PM
JeremyB's Avatar
JeremyB
I tried double sided tape but i think in the heat it doesnt hold very well because the plate keeps on rattling.
Old Jul 25, 2011 | 12:48 PM
quikmni's Avatar
quikmni
On my GP, I have a simple black license plate frame that uses four screws (two top and two bottom) to hold the frame and license plate to the OEM license plate mount. The OEM license plate mount is attached to the car only at the top. I only get a rattle when I close the rear hatch.
Old Jul 25, 2011 | 12:51 PM
JeremyB's Avatar
JeremyB
Mine is the exact same way but it rattles all the time, maybe ill jsut glue some rubber on the back of the plate, i was just trying to avoid having the rubber rub on the Matt Black finish where the plate is and scuffing it since the matt black is a soft paint
Old Jul 25, 2011 | 02:25 PM
quikmni's Avatar
quikmni
Maybe you should temporarily wedge a little piece of foam between the mounting bracket and car body to verify that stops the rattle before glueing a rubber piece that will probably mark the matte black.
Old Jul 31, 2017 | 10:54 AM
isamin's Avatar
isamin
I can't believe that you haven't had it TIG welded yet.
ISAMIN
Old Jul 31, 2017 | 11:52 AM
JeremyB's Avatar
JeremyB
ISAMIN
UPDATE! Drove me F**KIN crazy. Removed the rear trunk inside panel and found small plastic debris inside the panel and the trunk lid possibly from the factory rattling around
Old Aug 9, 2017 | 01:24 PM
Capt_bj's Avatar
Capt_bj
6 year resurrection . . .
in running for today's longest reach back award
Old Aug 11, 2017 | 06:52 PM
MoFasterMo's Avatar
MoFasterMo
Lowe's sells rubber stoppers. Buy 2 and run 2 more bolts in the bottom holes into the stoppers, no more rattle
Keet
Suspension
Aug 30, 2016 03:46 PM
n0mis
MINI5280
11
Mar 9, 2016 05:04 PM
eliseo1981
Sep 30, 2015 07:57 PM
Huskyfan
GP Talk
Sep 28, 2015 06:08 PM
