Pepper white stained from Stripes?
Old Jan 13, 2011 | 08:21 PM
hbSean's Avatar
hbSean
So today I was going to get a clear bra installed and when I got there I had the guy take off the stripes and soon as he took off 1, we noticed that right above the Scoop its stained yellow..
These are the best photos I have of it right now...
my editing skills
Has anyone had this happen?
Should I call the dealer and see if they will cover the costs of having it corrected by a professional?
Ill try to get better ones if the sun is out tomorrow
Old Jan 14, 2011 | 12:03 AM
BensMini's Avatar
BensMini
Well it is somewhat noticeable although the photos don't really give true colors. Have you tried any cleaners on the affected areas?
Old Jan 14, 2011 | 12:34 AM
hbSean's Avatar
hbSean
I tried Pre-Wow but It did nothing.. Ill post better photos tomorrow before work
Old Jan 14, 2011 | 01:44 AM
OctaneGuy's Avatar
OctaneGuy
This is NOT the type of thing Pre-Wow or any cleaner is going to remove. Pepper White is the only MINI paint that stains like crazy. The only way you will improve this is through machine polishing with a paint cleaner. Putting on a wax won't help either. it's a shame your paint is so swirled out. How are you washing your MINI?
You should bring your MINI by my shop and we can see what can be done. I'm out of the country right now but will be back at the end of next week.
Old Jan 14, 2011 | 01:45 AM
hbSean's Avatar
hbSean
Forgot I took some with my phone:
Attached Thumbnails Pepper white stained from Stripes?-photo-i.jpg   Pepper white stained from Stripes?-photo.jpg
Old Jan 14, 2011 | 01:48 AM
hbSean's Avatar
hbSean
Those swirls were under the stripes
Old Jan 14, 2011 | 01:53 AM
OctaneGuy's Avatar
OctaneGuy
Well I've never seen swirls on any MINI under factory stripes, so the stripes must have been put on by the dealership or by someone else at a later time after delivery.
I have seen PepperWhite paint stained by Meguiar's Quick Detailer, and by unknown substances on the street that a PW driver drove over and splashed all over his car. So I'm not at all surprised to see this. Again, without more information, I must assume the stripes were not factory installed based on the condition of the paint and the installer did a wet install with the stripes. The solution caused the staining to occur.
Richard
Old Jan 14, 2011 | 02:07 AM
hbSean's Avatar
hbSean
Well I didn't know that the stripes are factory installed.. Most likely they installed them when it was a lot car.
Old Jan 14, 2011 | 02:14 AM
OctaneGuy's Avatar
OctaneGuy
My point is simple. The paint under the stripes are swirled meaning that the paint was damaged by someone other than the factory. Usually the dealer does the damage or a third party. The fact that the paint is stained under the stripes means that something was applied to cause the staining. In my experience, this was a wetting solution. The only way you are going to solve or minimize the staining is through paint removal, i.e. paint polishing.
Old Jan 14, 2011 | 08:30 AM
krishnika's Avatar
krishnika
OG - not pleased to hear that a QD can stain my paint!! Any brands besides Meguiars to avoid? thanks.
Old Jan 14, 2011 | 08:53 AM
OctaneGuy's Avatar
OctaneGuy
I've only had issues with thei Quick Detailer in the maroon bottles..but it doesn't happen every time. Just something to be aware of.
Old Jan 14, 2011 | 10:53 AM
Stealth 993's Avatar
Stealth 993
You need some polish on it, not a "cleaner". I bet it also needs to be clayed. Why not just get the exterior detailed?
Try to stay away from any auto parts store car care products, stick with speciality products. I have tried just about every QD out there, for the price I like the Griot's speed shine, or Einszett QD. Always get it in the biggest size you can get, it goes like water.
I also agree it's weird that the car is scratched under the stripes. Maybe they stained the paint, tried to "fix it" then put on the stripes.
You should polish the paint before doing clear bra anyway.
Old Jan 14, 2011 | 03:44 PM
hbSean's Avatar
hbSean
What polish should I get? I have Griots polish 3 and I did use it this morning with the Griots DA and I helped but with 3 passes its still there.
Old Jan 14, 2011 | 05:34 PM
OctaneGuy's Avatar
OctaneGuy
If it helped, it probably means you need time. Whenever I've performed stain removal on Pepper White, I used a rotary buffer and polished for a LONG TIME. I'm telling you, to fix this stain, you will have to remove a significant amount of paint. If 3 passes on your DA helped, then don't stop until you've done 15 or 20 passes.
Richard
Old Jan 14, 2011 | 06:25 PM
hbSean's Avatar
hbSean
Sounds good. Just didn't want to keep doing it since Im to new this..
Old Jan 15, 2011 | 10:32 AM
Stealth 993
You need a rotary, or use the DA for quite some time. IMHO, Griot's polishes are idiot proof, but very mild. Get some Lake Country pads, like yellow, orange & green.
I would use some Menzerna SIP, then follow up with Menzerna 106. These are "big boy' polishes all the pro's use. SIP will dust, you need to work it in for quite some time with a DA. Use the top speed, you want to build up some heat.
USNAE2
16
Jun 17, 2022 07:17 AM
Doc Pain
Mar 10, 2021 04:50 AM
gar56
Nov 15, 2016 06:41 AM
Alpha Motoring
Oct 1, 2015 10:30 AM
krohm
Sep 28, 2015 12:16 PM
