Good Wiper Blades?.........
Old Mar 2, 2010 | 09:27 AM
martinb's Avatar
martinb
Hello,
I got my Mini last summer (a nice used 06 full JCW cab) and on a subsequent road trip, discovered that the wiper blades were shot. (Southern California car so likely little rain or incentive to replace them.) So, I went to the Mini dealer and bought some new factory inserts. They're terrible. They chatter all the time on the upstroke. I cleaned the windshield really well. No improvement. I cleaned and treated the windshield with Rain-X. No improvement. Recleaned the windshield and cleaned the blades. Still chatters like crazy on the upstroke. So......
Did I just get a bum set of inserts? Or is there a better aftermarket supplier? Just the insert would be great. But if I have to buy the frame as well, that's OK too. But I'd like to be able to just buy the inserts the next time rather than keep buying the whole frame/holder for the blade, so a manufacturer that sells the inserts separately for their holders would be preferred. Also, I don't want those big horsey double blade affairs with airfoils and wings and such.
Any and all recommendations appreciated.
Thanks much!
Old Mar 2, 2010 | 09:34 AM
lotsie's Avatar
lotsie
Bosch Icon's I've been using them for a few years now, very happy with them.
Mark
Old Mar 2, 2010 | 09:39 AM
OPC's Avatar
OPC
RATTUS Deserticus
I like the PIAAs, but they are pricey.
Old Mar 2, 2010 | 10:02 AM
04Mini-S's Avatar
04Mini-S
Mark
I agree. Very quiet and a very clean wipe every time.
Old Mar 2, 2010 | 10:43 AM
ZippyNH's Avatar
ZippyNH
Well into my second year....no streaks....no lift off at speed....curve fits mt GEN1 mini great, 100% coverage.....be sure to get the Silicone ones..The ones I got are curved.....they have a cheaper Carbon/rubber ones that I have not heard good things about....they arun about $35 a pair....are great quality items...look nice too!!
I tried the newer single blade/holder types....they did not curve enough to give 100% coverage on a MINI.
http://www.outmotoring.com/mini-coop...ni_cooper.html
PIAA's super silicone wiper blades have proven to be among the best wipers blades on the market and are excellent at what they do. If your MINI Cooper needs new wiper blades, these make an excellent choice.
The wiper insert of all PIAA wiper blades is made of silicone rubber, which ensures greater visibility by coating the windshield with silicone to promote continuous water beading in inclement weather. Water beads up into droplets at low speeds that are easily removed by ordinary wiping. And at higher speeds, wind pressure pushes the water off the windshield, often without even requiring wiper use. The silicone coating also reduces drag and eliminates annoying and inefficient chattering, regardless of the shape of the windshield to provide greater comfort for both driver and passenger. And the best part is that PIAA Super Silicone Wiper Blades reapply the silicone coating every time the wipers are used.
PIAA wiper blades maintain a sharp, clean edge and offer better resistance to all climates - heat, ozone, ultra-violet, and wear - clearly out performing the industry standard.
Sold as a matching front set of both passenger (19") and driver (18") and are complete replacements for the stock wiper blades. There is not a PIAA replacement wiper for the rear.
Last edited by ZippyNH; Mar 2, 2010 at 10:49 AM. Reason: added quite/link to wiper info and sizes
martinb's Avatar
martinb
Thanks for those suggestions. I found this article and was wondering if the problem described in the article is also there with the Mini:
http://www.carbibles.com/productrevi...xlatitude.html
Old Mar 2, 2010 | 10:44 AM
kalililly's Avatar
kalililly
If they are chattering they may just need an adjustment. There is another thread about chatter on this site. I also saw a You Tube article about this and the 'mechanic' did an adjustment which stopped the chatter. This is basically about the angle the blade makes with the glass...Try You Tube "Mini Cooper Wiper Blade Chatter, DIY..."
Old Mar 2, 2010 | 10:45 AM
martinb's Avatar
martinb
Hmmmm.....that was one of the things I was wondering about. 100% coverage is important to me. Especially with a 1st gen cab.
Thanks.
Old Mar 2, 2010 | 10:47 AM
minicooperwill's Avatar
minicooperwill
Try this:
martinb's Avatar
martinb
Compared to the prices I've seen for the Icons, the PIAA's are downright cheap.
Old Mar 2, 2010 | 10:56 AM
Tsiggy's Avatar
Tsiggy
Alliance Member
I have the Latitude wipers from RainX....at first they seemed a bit chunky looking on the car but my wife told me to stop obsessing....they work great. Kept the old wiper if I ever want to go back. Hope this helps....Cheers
Old Mar 2, 2010 | 10:57 AM
martinb's Avatar
martinb
minicooperwill: all I get is a blank white box on my screen.
Re the PIAA's. Do you guys use the Super Silicone or the curved Super Silicone. Or do you use the Super Sporza?
Old Mar 2, 2010 | 11:06 AM
minicooperwill
Hmm, IDK, it is working fine for me. Is it working for anyone else?
Old Mar 2, 2010 | 11:30 AM
ZippyNH's Avatar
ZippyNH
[quote=martinb;2995805
Re the PIAA's. Do you guys use the Super Silicone or the curved Super Silicone. Or do you use the Super Sporza?[/quote]
Curved Super Silicone!!
Simply ingenious!! Hugs the windshield perfectly like OEM. No complaints.
Factory wiper blades seem to last 6 months....OK when free....but still a pain...especially after the free ones run out!!
Old Mar 2, 2010 | 11:33 AM
ZippyNH's Avatar
ZippyNH
Originally Posted by minicooperwill
Try this:
It apperas on my screen.....fine....they basicly just bend the wiper arm....if a car is in storage for long periods....it can bend slightly causing some chatter.....it will not effect streaking or coverage....just fix SOME chatter issues due to the arm being bent. Cars that have spent all winter in storage can have this issue.
Old Mar 2, 2010 | 11:40 AM
OPC's Avatar
OPC
RATTUS Deserticus
I am using the base Silicon with no issues.
One thing to mention, the PIAAs come with a little windshield-prep wipe (silicon impregnated) that seems to do wonders for how the wiper rides on the glass. After prepping the windshield, I almost don't need the wipers.
Old Mar 2, 2010 | 01:40 PM
martinb's Avatar
martinb
Thanks all of you for the suggestions. Especially the one about tweaking the wiper arms. (Finally got the link to work.) I went out at lunch and tweaked them a bit. Fortunately, it was sprinkling, so I was able to test them. Improved with the first tweak, a little better with the 2nd tweak, and finally, totally cured the chatter with the third tweak. (I was being cautious with my bending.) Bottom line: Not a hint of chatter, full 100 % coverage, perfectly clean sweep. Nice.
Thanks so much again! Cheers!
Old Mar 2, 2010 | 02:42 PM
minicooperwill
Its always nice when something you see online actually works for you.
Old Mar 2, 2010 | 02:47 PM
lacning74's Avatar
lacning74
i'm running the PIAAs as well. they work well with my Aquapel treated windshield.
Old Mar 2, 2010 | 04:07 PM
CFMINI's Avatar
CFMINI
PIAA's +6 ( I think) Curved Super Silicone
Old Mar 2, 2010 | 04:40 PM
martinb's Avatar
martinb
Maybe when my current inserts wear out, I might try the carbon fiber PIAA's. They might go nicely with my other carbon fiber trim pieces.
Old Mar 2, 2010 | 05:15 PM
Crashton's Avatar
Crashton
Mark
+1
They are the best wiper blades that I have used to date. They are on all of our cars.
Old Mar 3, 2010 | 08:02 AM
Bigshot's Avatar
Bigshot
Been using the Silblades for years on our cars with no complaints.
Love the lifetime warranty.
Chattering can also be caused by the rubber going hard.
Old Mar 3, 2010 | 12:37 PM
TimL's Avatar
TimL
Based on recommendations here I bought a set of PIAA Silicones (straight) from OutMotoring to replace the Rain-X wipers (not Latitudes... something else) that the previous owner had installed. I actually thought the Rain-X wipers were pretty good, they just had gotten very old.
Based on the past couple of weeks -- including some pretty good downpours -- the PIAA wipers seem pretty good.
Old Mar 3, 2010 | 01:45 PM
Gromit801's Avatar
Gromit801
Got those last year, and they don't give 100% coverage. The blade can't follow the curve of the Mini windshield. They do ok, but not going to buy them again.
