Accuracy of the odometer
Old Sep 4, 2009 | 06:52 PM
Btwyx's Avatar
Btwyx
Despite the well known (in)accuracy of the speedometer, the odometer seems to be pretty accurate. So today we had a long trip (Salt Lake City, UT to Fallon, NV via Hwy 50), and we didn't make any detours. I noted the odometer reading at start and end and its 500 miles (could be 499-501 miles). Google maps reckons the trip was 499 miles, my TomTom reckons 501miles, so that seems pretty accurate. Within 1 mile over 500 miles is 0.2% accurate.
This accuracy seems to be independent of the tire size, I'm running 205/50-16 tires which are about 1.5% smaller than stock.
So how does the MINI do it? How does it correct for tire size etc? I have some theories that it could use the accelerometers to calibrate the tire size. But does anyone know?
Old Sep 5, 2009 | 07:40 AM
MINIfixer's Avatar
MINIfixer
SPEEDO.pdf
Old Sep 5, 2009 | 08:36 AM
rkw's Avatar
rkw
I would be very surprised if the odometer worked by doing anything more than counting wheel revolutions and multiplying by a fixed, standard value. If 1.5% higher mileage was expected, there are several tolerance variations that could have accounted for it. Vehicle load, tire pressure, sidewall stiffness, and amount of tread wear all contribute some variation. Even the line you take on each turn affects the distance. Nor do I trust Google Maps or a TomTom to calculate distance with very high accuracy. I think you need to get the odometer reading for a measured mile (and read odometer off the OBD for the extra decimal places).
Old Sep 8, 2009 | 04:57 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
This one time my odometer went crazy and racked up about 10 miles in the length of only 1. This was days after I had taken out an abs fuse, a side of which was no gauge activity, including the odometer. I put the fuse back after only several miles. Maybe the car recorded the mileage in the computer and reconciled the gauge read out later.
Old Sep 9, 2009 | 07:50 AM
Bigshot's Avatar
Bigshot
GPS is the MOST accurate way to measure both speed and distance.......
Old Sep 9, 2009 | 08:24 AM
Porthos's Avatar
Porthos
Meh its all relative as long as its reading within a mile or two its good.
Old Sep 9, 2009 | 01:36 PM
NightFlyR's Avatar
NightFlyR
Ok so this is a little off topic but I figure a good place to ask, were is the information stored for the mileage? is it stored in the speedo or on the computer someplace.
Reason i am asking is i am having my speedo and tach re done with different color LEDs and I purchased a used speedo and tach to use while the other one is out, so I am not sure what Mileage will show up. I am guessing this is stored on the computer and just fed to the odometer, but again just a guess
Old Mar 7, 2011 | 02:51 PM
Bruinjustin's Avatar
Bruinjustin
My 2011 mini reads my daily work commute distance as 34 miles where google indicate the distance as 20.9 miles. I just dont know what I am to make out of it.
Can dealer do anything about this?
Old Mar 7, 2011 | 02:59 PM
MP1.6T's Avatar
MP1.6T
Well, that's likely a different issue completely
Try setting Google for streets traveled distance, not straight line. Your car does the former. As they say, crows do the latter.
Old Mar 7, 2011 | 03:27 PM
Bruinjustin
i did set the google for street straveled distance. and it reads 20.9 miles just as my other cars (prius, Sorrento 2011, etc.) but somehow, I take the same route, mini reads 34 miles.
Old Mar 7, 2011 | 08:14 PM
bOOb's Avatar
bOOb
Now it makes sense..
1 mile = 1.609344 kilometers
reset your display to mph
triple5soul
Nov 19, 2019 07:46 AM
DeniseNY R52
May 17, 2016 05:16 AM
wyliec0y0te
Sep 15, 2015 01:13 PM
JamJam43087
Aug 16, 2015 02:02 PM
FrostyFox
Aug 12, 2015 02:33 PM
