Cone air filter???
Old Mar 12, 2009 | 02:33 PM
n733lk's Avatar
n733lk
Cone air filter???
I'm a virgin to all this 'performance' stuff. I read in a thread somewhere that replacing the stock air filter with a cone air filter is a good idea. Why? Cost? Type and material recommendation?
Thanks.
Old Mar 12, 2009 | 02:51 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Well, an aftermarket filter can improve airflow, smooth out throttle response, add more noise, and it is washable/reusable.
There are countless intakes on the market for all the MINIs. They are all pretty much the same. I have an old Alta 1.0 Cold Air Intake (CAI) with an itg CAI replacement filter from Minspeed.
Old Mar 12, 2009 | 03:05 PM
Pinky Demon's Avatar
Pinky Demon
Thanks.
Alright, I'll sort this one out for you.
There are two major types of intakes. The first, which is a sort of box with a filter element inside filtering the air as it gets sucked in, and the open element, more often referred to as CAIs, or cold air intakes. Basically, an engine needs air for combustion. When you let cooler air, at larger volumes in, it means the engine does not have to work as hard and it increases efficiency. Most CAIs just get rid of the airbox w/ the filter and instead replace it with a cone filter element, just right out there in the open. This allows more air to flow into the engine, as well as allows for colder air to come in.
However, this is one big downside to this, and oh boy, is it a biggie. If a large amount of water gets sucked into your intake, it can cause a hydrolock, in which the engine can not combust because of too much water in the cylinder.
Any other questions?
Old Mar 12, 2009 | 03:17 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Important note: itg makes panel filter replacements that could essentially do a better job than most CAIs.
Old Mar 12, 2009 | 08:10 PM
Pinky Demon
Link to said product?
Old Mar 12, 2009 | 08:13 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
http://www.minspeed.net/ITG.htm
Old Mar 12, 2009 | 08:14 PM
Pinky Demon
Not bad, not bad. Good for a drop in filter. I still say an open element would be better though, especially if you open up the hood scoop a bit.
Old Mar 16, 2009 | 02:52 PM
n733lk's Avatar
n733lk
How does the ITG compare with the Alta drop in filter?
Thanks gang!
rtk90
Aug 29, 2019 09:08 AM
Filmy
Sep 7, 2015 08:27 PM
eliseo1981
Sep 4, 2015 02:33 PM
Ntety
Sep 2, 2015 08:39 PM
Sep 2, 2015 11:15 AM
