General MINI TalkShared experiences, motoring minutes, and other general MINI-related discussion that applies to all MINIs, regardless of model, year or trim.
can a sway bar really do that for you? as far i'm concerned the mini already almost drives like it has the bose suspensions around the corners.
That's because you MINI DOES have (anti)sway bars already... the test vehicle doesn't.
The sway bars are also what makes the "sports car" in their test videos bounce like heck on the bump tests - because it ties the right and left suspension together, so they more or less as a single unit - that's the downside of sway bars, and what the Bose active suspension approach should do better...
Stiff suspension with sway bars = great in corners, crappy over bumps
Independent suspension, no sway bars = soft over bumps, crappy in corners
