Compatibility between the 1st and the 2nd gen?
Old Jan 15, 2008 | 06:04 PM
jfman's Avatar
jfman
Is the 2nd gen mini a completely dierent car than the first gen? Anything that is interchangeable between the two gens?
Old Jan 15, 2008 | 06:10 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by jfman
Is the 2nd gen mini a completely different car than the first gen? Anything that is interchangeable between the two gens?
Tires? Some brake parts depending on what you have on the R53? Fluids. Probably a couple of other things.
///Rich
Old Jan 15, 2008 | 06:26 PM
jfman's Avatar
jfman
That's it ??? whoa... They look so similar..
Old Jan 15, 2008 | 06:57 PM
roaduscarnivorous's Avatar
roaduscarnivorous
the driver is also interchangeable
Old Jan 15, 2008 | 07:00 PM
Rich.Wolfson
I am sure there are some other parts that are interchangeable too. But although the cars look similar almost ever dimension is changed. As has the engine and transmission. As I suggested not even the wheels are the same. But I am not sure about all the suspension parts. My guess is some other can be more specific.
Rich
Old Jan 15, 2008 | 07:33 PM
jfman's Avatar
jfman
Ok got you.
Old Jan 15, 2008 | 09:09 PM
CooperGear's Avatar
CooperGear
From: Greater Chicagoland. Ich Bin Ein Midwesterner!!!
External door handles are interchangeable between the two generations.
Old Jan 15, 2008 | 10:35 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
The doors look very similar...
Old Jan 16, 2008 | 03:33 AM
Silverbullit's Avatar
Silverbullit
I think the fun factor is interchangable!!
Old Jan 16, 2008 | 09:26 AM
sequence's Avatar
sequence
the body pan is identical
Old Jan 16, 2008 | 09:55 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Are they the same design, or has the design changed but retained the same fitment?
I wonder if the mirrors are interchangeable.
Some of the suspension bits (struts, coilovers, rear control arms) can be interchanged. Camber plates won't work though.
Old Jan 16, 2008 | 10:01 AM
cristo's Avatar
cristo
Alliance Member
Can use the same gas credit card for both.
Old Jan 16, 2008 | 10:05 AM
gokartride's Avatar
gokartride
Maybe the cigarette lighter, but I wouldn't count on it.
Old Jan 16, 2008 | 10:08 AM
AeroJammin's Avatar
AeroJammin
I believe that some of the brake components will work since the R56 brakes are essentially the same as the 1st Gen JCW brakes. I believe there are some threads that go into more detail concerning what one would have to do to put R56 brakes on a R53.
Also, anyone know if it would be possible to retrofit the seats from and R56 into a 1st Gen?...just curious
Old Jan 16, 2008 | 10:14 AM
ThePritchett's Avatar
ThePritchett
The mirror assemblies are not the same, but they may be interchangeable.
The R56 mirrors come to more of a point on the outside. The mirror capsr from an R53 will not fit on mirrors from an R56.
Also, it seems that the aluminum rear arms from the R56 and GP can be retrofitted to the R53. There are quite a few parts involved in this swap and it doesn't look to be cheap.
I believe the aftrermarked adjustable rear control arms from the R53 can be used on the R56.
I'm a big fan of the new seats and would be interested to find out if I can easily bolt them into my 06 MCS (and retain airbag functionality). I doubt the rear seats would fit, but mine may get removed soon anyway.
Old Jan 16, 2008 | 01:53 PM
Funk_Flex's Avatar
Funk_Flex
The magnetic stone chip protector can be used on both models.
gknorr
Oct 2, 2015 01:06 PM
BadgeFTW
15
Sep 20, 2015 11:39 AM
Andrew Namel
Sep 12, 2015 08:49 AM
Eurothrasher
Sep 9, 2015 12:00 PM
