Manual trans fluid
Old May 21, 2007 | 02:46 PM
hemiheaded18's Avatar
hemiheaded18
Manual trans fluid
Mine is an 03 non-S and I'm sure the trans could ude the scheduled maintenance. I'm at about 53,700 right now. My question is, what do I use? I've heard good things about RedLine which I can get through work. But, what weight?
Old May 23, 2007 | 11:37 AM
hemiheaded18
Anybody? And yes, I realize now that I'm retarded and spelled the title wrong.
Old May 23, 2007 | 11:42 AM
Skuzzy's Avatar
Skuzzy
Manual transmission typically use grease or gear oil. Fluid is usually for the automatic transmission. Just FYI.
I do not see in my owner's manual the weight of the lube used in the transmission though.
Old May 23, 2007 | 11:47 AM
hemiheaded18
Yeah, I know and I see that I did quote it wrong. But, a lot of Honda's actually use 10W30 as manual trans fill. All I need is a weight and hopefully, a reccomendation.
Old May 23, 2007 | 12:13 PM
Edge's Avatar
Edge
AdMINIstrator
Corrected.
Old May 23, 2007 | 12:18 PM
hemiheaded18
Originally Posted by Edge
Corrected.
Sweet, thanks. Now maybe people will read my post instead of thinking I'm talking about some weird fluid that dosen't exist.
Old May 23, 2007 | 12:27 PM
Xiek's Avatar
Xiek
I looked in Mitchell and it doesn't list it either, call the dealer and ask.. that is what I am gonna do for my 04.
J
so I just called and they said that there is a label on the bottom of the pan that tells you.
can't find the label though
Old May 23, 2007 | 04:16 PM
NMgokart's Avatar
NMgokart
Redline MTL (70W80) is a direct replacement for the OEM gear lube. I switched, felt no difference. Go with whatever is least expensive in the synthetics.
09R56
Nov 16, 2022 10:49 AM
cawwwtun
May 3, 2016 08:03 AM
MiteyF
Aug 26, 2015 05:07 PM
06R53
Aug 26, 2015 08:37 AM
minipopkart
Aug 13, 2015 05:22 AM
