General Discussion Competiting with the new MINI on track or at a SCCA Solo event.
Running no rear sway bar for track?
Old Sep 22, 2012 | 02:00 PM
NintenTom's Avatar
NintenTom
I've heard of people not running a rear sway bar for auto-X, but is it advisable for the track? I specifically go on Infineon (Sonoma) and Thunderhill most of the time. Would I be experiencing major understeer or oversteer?
Old Sep 22, 2012 | 03:36 PM
cmt52663's Avatar
cmt52663
That's a new one for me.
Two reasons why I wouldn't:
1. more body roll will not help the front camber, reducing front grip and increasing tire wear, and
2. increased understeer...
Are you concerned about spinning the car? Is your setup prone to swapping ends?
Cheers,
Charlie
Old Sep 22, 2012 | 03:54 PM
Lazlo10S's Avatar
Lazlo10S
^+1
I don't know a lot about setting up a car for a track, but I'm pretty sure you don't want to go without sway bars.
Old Sep 22, 2012 | 04:24 PM
NintenTom's Avatar
NintenTom
Cheers,
Charlie
No I have not spun out before in the current setup even when the sway bar stays on max stiff for track days.
Old Sep 22, 2012 | 11:27 PM
slinger688's Avatar
slinger688
What run group do you run in for HPDE?
Old Sep 23, 2012 | 12:36 AM
NintenTom's Avatar
NintenTom
Group 3
Old Sep 23, 2012 | 12:44 AM
slinger688's Avatar
slinger688
Group 3
Not sure what that translates to. Do you run solo?
Old Sep 23, 2012 | 05:35 PM
NintenTom's Avatar
NintenTom
Meant to say HPDE 3. So yes, it's a solo run group.
Old Sep 23, 2012 | 07:39 PM
Blackcoffee's Avatar
Blackcoffee
It's common not to run a REAR sway bar in a BMW. However, BMW's are rear wheel drive and if the rear is too stiff you end up lifting the inside rear tire.
I would think that if you we're going to pull a sway bar on a MINI, you'd want to pull the front.
Old Sep 23, 2012 | 08:23 PM
slinger688's Avatar
slinger688
Then I would suggest you read the book: going faster, mastering the art of race driving by Carl Lopez. It answers most of the questions you seem to have and includes a section in car setup.
Old Sep 23, 2012 | 11:07 PM
NintenTom's Avatar
NintenTom
I've heard great things about that book. Just ordered a used copy off Amazon.
Old Sep 24, 2012 | 07:48 AM
quikmni's Avatar
quikmni
I suspect that you heard of not running a rear sway bar from people with rear wheel drive cars. As has been stated you want the rear sway bar on the Mini Cooper and probably even a stiffer rear sway bar to reduce the understeer.
Toolman
Jan 20, 2016 06:50 AM
nomar116
Aug 10, 2015 11:24 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
