General Discussion Competiting with the new MINI on track or at a SCCA Solo event.
problems mounting v710s
Old May 16, 2008 | 02:40 PM
grodenglaive's Avatar
grodenglaive
I have a set of v710's that the garage is having trouble mounting. They are 215/40r16 and the rims are 16x7 Motegi mr7. According to Kumho, they should fit. The tires are on the rim, but they can't get them to pop into the seat, so they won't take any air.
Is this common with low profile r-comps? Any suggestions?
Old May 16, 2008 | 02:44 PM
ScottinBend's Avatar
ScottinBend
I have no idea why they would have any problems mounting those tires. They should fit just fine.
Old May 16, 2008 | 04:47 PM
grodenglaive
I get the feeling they're not too experienced with competition tires.
Old May 16, 2008 | 07:04 PM
TLMCS05's Avatar
TLMCS05
Use the ATV trick and throw a ratchet strap around the center of the tire and make sure the valve is out of the stem. Lots of airpressure and no resistance from stem and they should seat. Hopefully
Tim
Old May 16, 2008 | 08:03 PM
LgEnf's Avatar
LgEnf
i have the V710s on stock 16s - mine are the 225/50/16 though so that may have helped
also I went to tire kingdom (they have a little bit of experience mouting tires)
Old May 17, 2008 | 03:51 AM
grodenglaive
Tim
Thanks Tim, I will tell them to try that. If they still have no luck after Monday, I'll take the wheels somewhere else.
Old May 17, 2008 | 07:18 AM
TLMCS05's Avatar
TLMCS05
Hopefully it will work. Have used the same trick with short track cars and quads. Maybe a tire store used to dealing with race tires? Good luck, let us know what works out.
Old May 22, 2008 | 04:43 PM
grodenglaive
well the first garage has given up, the ratchet strap didn't even work for them. I'm going to a tuner place with more experience with the low profile stuff.
Old May 22, 2008 | 07:09 PM
TLMCS05's Avatar
TLMCS05
Wow, may be issues beyond the norm here. Keep us posted. See if there is a local SCCA chapter that has a favorite tire store and skip to the experts that way.
Tim
Old May 22, 2008 | 07:10 PM
TLMCS05's Avatar
TLMCS05
Or the Canadian equivilent?
Old May 27, 2008 | 08:50 AM
grodenglaive
here it's the CASC. The rules and classing are pretty much identical with SCCA, they just scrambled the acronym
Well the 2nd garage mounted 3 tires with no problem, but they failed with the other one. There is a defect in the tire that causes the bead to bulge away from the rim at one point. It's not very noticeable, but it's enough so it won't hold any air. I'm going to exchanging the tire.
Old May 27, 2008 | 10:36 AM
TLMCS05's Avatar
TLMCS05
WOW, that could have been an ongoing PIA! Glad things are working out finally!
Tim
Old Jun 1, 2008 | 11:28 PM
rustspot's Avatar
rustspot
yeah 710s are tough to mount. and i had the same problem but did managed to get them all to seat even in stock rims so dont blame it on the defect (hard side wall tends to do that). i use a tire machine like fallowing to mount mine . there is an arm that extends out to help to push the tire in and help the air seal . we had to use lighter fulid and fire to pop one of the tires(spray flamable substance in the tire, set it on fire and let the air expand and pop in place) but yeah, not easy to mount
Old Jun 2, 2008 | 07:34 AM
grodenglaive
The tire dealer (TalonTire) tested it out and found that it was indeed more difficult than usual for a v710. They figured they could manage to do it with a bit more time, but decided to send me a replacement anyway.
Toolman
Jan 20, 2016 06:50 AM
silence2-38554
Nov 12, 2015 09:39 AM
Mini'mon
Aug 16, 2015 12:47 PM
Phantogram
Aug 12, 2015 12:11 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
