Got Yellow Engine Light on Way Home From Dealer
Old Jul 1, 2011 | 04:08 AM
laneess's Avatar
laneess
Hi All!
Last night, I bought the 2011 's' I had test driven a few days ago. The salesperson (an 's' owner) filled it with gas and had it prepped while I did the final paper work.
Shortly after driving off the lot, the yellow check engine light ('no full power') came on. It was already way past closing time, so we couldn't just turn around. I'm hoping that it is just the gas cap, but the car didn't seem to be as peppy as it was when I test drove it.
It goes back this morning. Just for fun, does anyone want to make any guesses?
Kinda ironic. We traded in a trouble-free 8 year old car because we were concerned that it may be getting old enough that we may start to see some problems and big service bills.
Old Jul 1, 2011 | 05:30 AM
tccox's Avatar
tccox
Wow that stinks but I bet you it's something real minor. Mines been pretty much trouble free aside from two defective tyres. 7000 miles now, no rattles, no problems complaints at all. Please let us know what the dealer finds.
Old Jul 1, 2011 | 06:17 AM
AustinS's Avatar
AustinS
I hope it's minor and that you are a short drive to the dealer.
Old Jul 1, 2011 | 06:35 AM
sean5294's Avatar
sean5294
My 2011 did the exact same thing lol, Im going to take it in soon
Old Jul 1, 2011 | 07:26 AM
highlander709's Avatar
highlander709
Probably something minor, don't be discouraged. My 11 MCS with almost 7K has been problem free. On another note, we just purchased a pre-owned (sounds better than used doesn't it) 2005 Nissan Titan 4x4 with 72,000 miles from a local car lot. It test drove great, everything worked well and the Carfax showed just two previous owners, both local, and all routine service and repair work done by a local Nissan dealer. We drove it home, did some additional clean-up work and then ran some errands in it. I went out later that night to drive it to make sure all the lights worked properly and there it was, the dreaded yellow "Service Engine Soon" light. We went back and forth on purchasing the "4 Year 48000 Mile Extended Warranty / Service Contract" offered by the credit union and finally did. I guess we may soon see if that was a good decison or not. Hopefully it's also just a minor issue.
Old Aug 5, 2011 | 11:25 PM
cesar418's Avatar
cesar418
any news?? my car has 12000 miles, and the light came on while driving today, i parked the car, turned the car off, waited, turned it on again, the light was still on for a while and then it turn off by itself, but im a little scared cuz of it, idk if its cuz there is something wrong or cuz i was driving it a little agressive as soon as turned the car on :/
Old Aug 6, 2011 | 12:03 PM
toyopet's Avatar
toyopet
Originally Posted by laneess
Hi All!
The salesperson (an 's' owner) filled it with gas...
...but the car didn't seem to be as peppy as it was when I test drove it.
Did the salesperson fill it with high octane? Is the sport button depressed?
Old Aug 6, 2011 | 12:40 PM
MandB's Avatar
MandB
Probably minor....on a related note, while our 2010 MCS was recently in for standard oil and filter service, the CHECK ENGINE light came on immediately on startup from the dealer parking lot. The service tech came right back out, took it back in, and within 10 minutes had the car ready to go....it was a sensor near the harness assembly which is very close to the oil filter. If it gets knocked or banged the wrong way, it can activate. I believe he either simply reset it or physically re-established the sensor connection near the harness. All was fine after that quick fix. He also indicated that there were a multitude of sensors throughout the car which could trigger that light. Given what he was replacing, however, he knew exactly where to go.
Old Aug 8, 2011 | 08:10 AM
Grimnebulin's Avatar
Grimnebulin
Same thing happened to mine after I took it home a few months ago. Yellow engine light went on the night I drove it home - took off gas cap and reinstalled and light went away. Three days later, the car almost completely died on the way to work and would barely idle/ran. Turned out it had a defective high pressure fuel pump which is apparently a common problem for the JCW as there was a bad batch made. They had to flatbed the car to the dealer and they replaced the HPFP and it has run great since.
Old Aug 11, 2017 | 05:43 PM
Jwp2's Avatar
Jwp2
sorry to revise an old thread but...
I just got a 2011 JCW, 45000 miles. Had the car a couple months and love it.
Recently, after getting a new tank of gas, the half yellow engine light came on. I have NO appreciable loss of power. I read some of the posts and read the OBD2 codes...
1. no codes indicated...seems ridiculous that there are no codes.
2. so thought it might be the gas cap.
just checked it and it looks good....put it back on and light still on.
3. it does NOT come on right away, but after a few minutes it comes on
4. recently, I hit a monster pot hole...rattled my fillings and I lost a front running light bulb but now I am wondering if this is related.
Is there a sequence that folks have used to check other potential causes?
any help is appreciated...thanks!
Old Aug 18, 2017 | 03:15 PM
Jwp2's Avatar
Jwp2
Help?
Old Aug 25, 2017 | 02:03 PM
petery's Avatar
petery
Dealer replaced thermostat on mine when I had CEL early this year.
Old Sep 10, 2017 | 04:27 PM
HZBJCW's Avatar
HZBJCW
Happened to me 2 times. I had the high pressure fuel pump go. The light comes on and it goes into limp home mode. 30mph max. That's a warranty item so don't sweat it.
I had a blow off valve go while driving off the lot after dealer service. Same symptoms but the code will tell you what to do. This is not warranty item. Its a plastic valve with a rubber seal so it is a wear item. But it is an easy fix (3 allen screws) and is inexpensive. WHile you are in there get an Alta spring. It really wakes up the car and cuts turbo lag to nothing between shifts.
CEL with no power loss is probably something different. No code either? Maybe get a different code reader. There should be something there.
09R56
Nov 16, 2022 10:49 AM
mini yellow-haa!
Aug 13, 2015 11:18 AM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
