235/40/17 on stock jcw challenge spokes anyone?
Old Jun 14, 2011 | 10:00 PM
chengchiro's Avatar
chengchiro
I have been running 215/45/17 on my 09 jcw challenge spokes. Has anyone
used 235/40/17 on the stock rims without rubbing?
Thanks for letting everyone know.
Old Jun 16, 2011 | 07:58 AM
etalj's Avatar
etalj
I've been running 215/45/17 on my stock challenge spokes, but I definitely wouldn't run 235/40 on them, they aren't wide enough.
That said, as soon as I get a job, I'll be buying genuine challenge wheels and putting 235/40 on those for sure.
Old Jun 16, 2011 | 10:16 AM
MP1.6T's Avatar
MP1.6T
Seems like too much...
As prior poster said, a 7" rim isn't going to be spec'ed for that width and profile tire.
FWIW though I am running 225/45-17's on Challenge rims. That works with no rubbing at all on a stock R56 S w/ factory sport suspension. Specifically, tires are Michelin PS2's. As you go wider (in whichever profile), look specifically at the sidewall measurement spec. To be clear too, specifically the sidewall width, NOT the tread width, which are two different things. TireRack shows it for many, but not all, tires. It varies by several tenths of an inch in some tires of the same nominal size. Having focused on it, had I picked a choice with a wider sidewall measurement, the sidewall (and not the tread edge) might have rubbed on the inner sidewall and the front fender liner. It clears completely as I said, but the free space is pretty small as it now stands.
Old Jun 27, 2011 | 02:18 PM
Wizeguy9999's Avatar
Wizeguy9999
For autox I'm currently running a 245/40/17 with a 3mm spacer and it doesn't rub. Hope that helps.
Old Jun 28, 2011 | 04:59 PM
oldcracker's Avatar
oldcracker
where can u get genuine challenge wheels from?
Old Jun 28, 2011 | 05:21 PM
sooper_cooper's Avatar
sooper_cooper
I think he's talking about these:
http://www.minigenuineparts.co.uk/mi...lengeR112.html
Old Jun 28, 2011 | 06:01 PM
El Matador's Avatar
El Matador
Wizeguy.. can you post some pics of this setup? Are you running C stock or STX?
Old Jun 28, 2011 | 06:23 PM
J&M'sMini's Avatar
J&M'sMini
El MatadorQuote:
...+1... I'd like to see pics
J
Old Jun 28, 2011 | 10:53 PM
sooper_cooper
Not the best photo, but these are 235/40-17s.
I'm curious to see 245s as well but I'd never be able to run that size without them rubbing on my coilovers, especially in the front.
Attached Thumbnails 235/40/17 on stock jcw challenge spokes anyone?-led_off_2.jpg
Old Jun 28, 2011 | 11:15 PM
oldcracker's Avatar
oldcracker
Originally Posted by sooper_cooper
what is the difference between the stock challenge ones and the genuine challenge ones?
Old Jun 28, 2011 | 11:27 PM
sooper_cooper
The genuine challenge wheels are 7.5" wide as opposed to only 7" wide on the stock wheels. Possibly they're lighter too, but that's just a guess.
Old Jun 29, 2011 | 06:35 AM
akng's Avatar
akng
According to:
The genuine challenge wheels are also 38 offset vs 48 offset on the JCW R112 wheels. But the Challenge car uses wheel studs, so I don't know if these genuine challenge wheels will fit on our road cars with no modifications needed!
Old Aug 2, 2011 | 09:43 AM
Formel1's Avatar
Formel1
No issues at all then with the 235/40 set up on JCW Challenge rims?
Dec 23, 2015 10:36 AM
G1HQ
Dec 7, 2015 02:23 PM
caiken
Aug 27, 2015 06:55 AM
Minibeagle
Aug 13, 2015 10:00 AM
