Slotted JCW rotors
Old Sep 29, 2008 | 08:01 PM
Krut's Avatar
Krut
Slotted JCW rotors
Do they fit with the JCW (Brembo) brakes? What diameter are they? Stock JCW Brembo Rotors are 12.4".
Old Sep 29, 2008 | 08:50 PM
AutoXCooper.com's Avatar
AutoXCooper.com
the R56S front rotor is 294mm X 22MM and the caliper is single piston and the rears are 259mm X 10mm, we make track pads for them.
The New JCW fronts are 316mm X 22mm with dual piston calipers and the rears are 280mm X 10mm with single piston calipers. We are working on pads for the R56 JCW brakes.
There is a set of OEM JCW cross drilled rotors that fit the stock R56 brake setup. Then there is the all NEW JCW dual piston setup that is bigger.
If you are looking for a better rotor for your R56 setup we will have the new TSW slotted rotor for sale by the end of the year. I also have the full line of Carbotech pads for ALL the MINI brake setups.
Old Sep 29, 2008 | 09:14 PM
NZ_M3's Avatar
NZ_M3
Part number 3411678437
See link here:
http://www.realoem.com/bmw/showparts...88&hg=34&fg=95
No. 11VENTILATED-PERFORATED BRAKE DISK 316mmX22mm
Old Sep 30, 2008 | 05:56 AM
Krut's Avatar
Krut
That looks incorrect.. they're referring to the Cooper S JCW - if you recall the 09 MINI JCW is it's unique animal but someone correct me.
MINI Cooper S JCW Brakes Upgrade
Stage 2 Brembos 09 MINI JCW
Old Sep 30, 2008 | 02:24 PM
NZ_M3's Avatar
NZ_M3
That is the stage 2 kit - there's a part number for the full kit upgrade on the normal Cooper S. It's the same kit as the JCW factory car bar the front discs - which is an upgrade item on the factory JCW car (if you don't believe me cross reference all the part numbers off the JCW factory Cooper S brakes with the Cooper S stage 2 JCW brake upgrade - they are identical bar the front disc).
On realoem it refers to the Stage 2 JCW car as the Cooper S JCW - same thing.
Just get the parts department to confirm disc sizing - it's the correct one.
The realoem page was recently updated, and I've cross referenced it with BMW parts on a couple of parts and all seems correct.
Do remember that the realoem pictures/drawings aren't always accurate - if you don't believe me do a search on the JCW carbon fibre rear diffuser for the JCW bodykit - it looks nothing like the actual thing - not even close. Similarly for the JCW factory exhaust system - it just has a generic picture/drawing for all Cooper S and JCW cars.
Old Oct 1, 2008 | 09:12 AM
Krut's Avatar
Krut
One of our salesguys ordered a JCW Stage 2 - the VDC put on the JCW slotted rotors - unfortunately when I measured the circumfrence of the rotors they are notably smaller by about 10 MM .
Old Oct 1, 2008 | 01:45 PM
NZ_M3's Avatar
NZ_M3
The sales probably ordered part number : 34116777826
Which is the 294mm x 22mm crossdrilled disc from the stage 1 brake kit.
Link here: http://www.realoem.com/bmw/showparts...32&hg=34&fg=95
As you can see completely different part numbers and different diameter discs.
Why don't you trust realoem.com? I've told you that i've cross referenced it with the parts guys at BMW NZ and it's the correct part number and sizing.
Old Oct 1, 2008 | 02:14 PM
Krut's Avatar
Krut
This was done by the VDC - the MA made the call to the VDC before they prepped his car. Not sure how the mixup happened. VDC is attempting to locate the rotors and send them to us.
Old Oct 1, 2008 | 02:19 PM
NZ_M3's Avatar
NZ_M3
Whenever I order anything I always do a check on realoem first. It's a good starting place - although not always correct (bumper clips on the mini for a start - there's two or three incorrect ones on there, but apparantly the same error on the dealer system too). The dealer system is more up to date and gives a bit more information and supercession numbers.
Good luck and let us all know how he gets on - the drilled and slotted discs should look quite good behind those Brembos - wish I had them on my car (might just have to order a retrofit kit I think )
Old Oct 8, 2008 | 04:17 AM
fignewton's Avatar
fignewton
I can confirm that there are slotted/drilled rotors for the new JCW because I saw them on a new car at Mini of Sterling last week. Showed on the sticker as about a $340 option, I think.
Fig
Old Oct 8, 2008 | 05:39 AM
Krut's Avatar
Krut
.. on a PW/PW car. Nice car - not very many options.
Old Oct 8, 2008 | 05:41 AM
fignewton's Avatar
fignewton
I've been thinking about that one. Wish it had the cold weather package. It did have the upgrade stereo. Don't think it had xenons, either, unfortunately.
Old Mar 2, 2009 | 06:27 PM
Minitauro's Avatar
Minitauro
Is there a rear rotor option?
Old Mar 6, 2009 | 05:41 AM
FON's Avatar
FON
I have these fitted in my factory JCW..i'll post some pics latter if you'd like.
Old Mar 6, 2009 | 06:24 PM
Minitauro's Avatar
Minitauro
Pics would be great
Old Mar 8, 2009 | 12:19 AM
Herman da German's Avatar
Herman da German
I thought maybe this link might help out some folks.
http://www.genuinemini.co.uk/acatalo...ni_Brakes.html
The rotors are about half way down the page. Don't see any back rotors though!
Old Mar 8, 2009 | 05:08 AM
Minitauro's Avatar
Minitauro
Good stuff - thanks for the link I ordered the JCW drilled/slotted front rotors from Morristown Mini last week. I'll post up pics once I get them on.
Old Mar 13, 2009 | 06:52 PM
FON's Avatar
FON
That is not the best..but for now, it is what i got..in a weektime, i'll get some very decent pics for you!
Old Mar 14, 2009 | 09:22 AM
belacyrf's Avatar
belacyrf
I'm waiting for a quality slotted rotor. I do not want cross drilled.
W0TM8
Dec 19, 2019 07:50 AM
minimofo
Dec 26, 2015 11:45 AM
aldito2
Nov 25, 2015 09:33 PM
fjork_duf
Tires, Wheels, & Brakes
Aug 16, 2015 04:38 PM
nomar116
Aug 10, 2015 11:24 PM
