I have 5mm wheel spacers all around so I could fit my wheels with summer tires. It is a very subtle change to the stance but is noticeable from stock. Don't have pics, but will try to get some and post up when I have a chance.
Go at least 12mm otherwise it's barely noticeable. I have some on mine and it helps the look of the stock offset a lot. And most come with them, just make sure longer bolts are included. I ordered mine from outmotoring.com
I just did spacers this past weekend, I will post photos later today. I went with 12mm in the front and 15mm in the rear with stock 18" pair spoke wheels. That puts my final offset at 39mm/36mm. I think 15mm would be too much in the front.
Okay, here's some spacer pics! These mainly show them from the side which I thought was most important. Let me know if you want to see additional pics.
Interesting, I have the same wheels 'chrisreece' . That looks pretty good. Did you need to get longer 'wheel bolts' or whatever they are called ? I hadn't thought about spacers on the Mini.
I have them on the Jeep and they are not bad, Give it a good wide stance. I'll have to look at the mini when it gets back home.
Installed. The pics I took in the garage don't really do it justice. Looks MUCH better now. 15mm is perfect for a proper OEM+ look. I'll try and get some better pics or better yet a vid of it going down the road where a bit better of a stance shows well.
Pictures please!!! I just ordered mine from ECS. They come with the bolts needed for either 12mm or 15mm.
Seems like you could even go with a 20mm but I wasn't sure. Thanks ECS for the quick shipping and great service!! Now to get some power with an Ecutuninggroup tune and a few goodies from Way Motor Works.
