F55/F56 Name That Part
Old Aug 16, 2014 | 03:13 PM
papawhiskey's Avatar
papawhiskey
Name That Part
Here are some pictures of my Mini Mystery part. This was found on the floor on the passenger side under the dash board. I don't know when it appeared there as the black on black carpet was near invisible. If I hadn't been cleaning the car it might still be there. I can't say if it fell out from under the dash or was just laying there since delivery or what. It's marked "RG/27973/100" and I can't find it on a Mini Site (eg Sewell) and a Google search finds nothing even remotely close. If anybody has an idea of what this thing might be, I'd like to know.
Old Aug 16, 2014 | 05:00 PM
hammerhands's Avatar
hammerhands
It looks like the tube that bleeds air into the glove box.
http://www.realoem.com/bmw/showparts...71&hg=51&fg=30
number 12
12 Ventilation hose, glove box 1 51169262368 See NoS No Stock
Old Aug 16, 2014 | 10:43 PM
Diana De Van's Avatar
Diana De Van
A round of applause for the correct answer! Nice work hammerhands!
Old Aug 16, 2014 | 10:46 PM
GregoryK's Avatar
GregoryK
It is a pig to get this to stay in place when you are installing the glove box.
Mine had a small fold on the large end not allowing it to seat properly. This had obviously happened at the factory but it was shoved in anyway. I fixed it when I had my glove box out for the driving lights install.
Old Aug 10, 2015 | 05:09 PM
turnersmini's Avatar
turnersmini
I just found this same part sitting on my passenger floor. Absolutely NO reason parts should be dropping off my car. Do I call the dealer, what do I do now?
Old Aug 10, 2015 | 05:21 PM
GregoryK's Avatar
GregoryK
It is not a big deal and very easy to fix. I can imagine that is tricky to install this part quickly on the line....
Old Aug 11, 2015 | 08:36 AM
papawhiskey
Now that this thread has bubbled back to the surface, it begs the question - is there some way to control this bleed air? More - Less? Hotter - Colder? And what the heck do I stick in the glove box that I want at a temperature different from ambient anyway - ham sandwich?
Old Aug 11, 2015 | 11:23 AM
hammerhands
Cold drink, I had a nifty toungue-in-cheek booklet with my R50. I think there's a PDF somewhere...
http://www.minipeople.lt/failai/db/4...ers_manual.pdf
You can turn [part 11 in diagram above] a vent in the back of the glove-compartment. It is using the cooling and heating from the vents.
Old Aug 11, 2015 | 11:32 AM
hanzov69's Avatar
hanzov69
I lived in South Carolina for a few years working at a place that required my phone remain in the car.
iPhones over a certain temperature will throw an overtemp alarm and refuse to work until they've cooled down a bit. I used the glove box with the AC cranked to get it functional again after work in the summer.
Old Aug 11, 2015 | 12:48 PM
JABowders's Avatar
JABowders
Veteran: Army
Double check... sometimes when a car is assembled, if a part is dropped they will just grab another part and install it, it cost to much to stop and search for the part that was dropped.
But there is a chance that it was installed poorly and has fallen off.
Motor on!
I like the thread... "Name That Part" we can make it a game...
Old Aug 11, 2015 | 12:50 PM
51169262368 #12 There is a valve that sets in the back 51162751723 #11, most of the time its set closed. When you open it and then run the A/C you have a cooled glove box. Goes back to the Gen 1 days .
Most likely it was on too loose and popped off or bumped under the dash.
Old Aug 12, 2015 | 09:08 AM
darex's Avatar
darex
Name That Part
Same thing happened on Edmund's Long-Term MINI Cooper.
Old Aug 12, 2015 | 10:01 AM
papawhiskey
51169262368 #12 There is a valve that sets in the back #11, most of the time its set closed. When you open it and then run the A/C you have a cooled glove box. Goes back to the Gen 1 days .
So is access to the valve from the insideof the glove box or do you have to reach up from under/behind to change it? (got the truck with me today or I'd go outside and figure it out for myself)
Old Aug 12, 2015 | 10:05 AM
The little valve is accessible through the glove box, its in the back corner. Turn it to close and open.
Old Aug 12, 2015 | 11:05 AM
MINIDean's Avatar
MINIDean
And....March 2015 and later builds do not have the cooled glove box anymore. Mine is not equipped and I bought the parts to retrofit.
Not to digress, but these are the items I have found that have been omitted from March 2015 and later builds:
  • Engine compartment shield on right side not installed.
  • Foam shield on coolant bottle not installed.
  • Screw caps on gauge cluster no longer installed.
  • Air-conditioned glove box discontinued. No hose or adjustable vent on glove box now.
  • Dark silver door trim instead of piano black when equipped with MINI Yours Fiber Alloy dash.
  • 100 MPH or more tire pressure label on door jamb discontinued.
  • Oil recommendation sticker in engine compartment discontinued.
  • Cargo net deleted (with storage package).
  • Cargo net retention slots on load floor deleted (with storage package).
Old Aug 12, 2015 | 11:10 AM
Still have the blank spot there ? For the small hose and the valve part ? for March 2015+
Old Aug 12, 2015 | 12:48 PM
MINIDean's Avatar
MINIDean
I had the blank spot. Had to buy the hose and the round grill to turn the flow off and on in the glove box. The outlet from the HVAC unit was capped off, so took the cap off and plugged the hose in.
Old Aug 12, 2015 | 12:58 PM
Nice , i am glad it was just capped off and you can add those parts linked above.
bobbiemartin
Jan 20, 2016 05:28 PM
ryGuyMCS
Oct 20, 2015 02:24 PM
Ryephile
Aug 25, 2015 06:51 AM
nomar116
Aug 21, 2015 04:36 PM
