F55/F56 week break
Old Sep 7, 2023 | 07:05 AM
Stu-mon's Avatar
Stu-mon
week break
if I take vacation for a week w/o running car, should I charge before, after, or both ?
Old Sep 7, 2023 | 07:55 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
My car has sat for more than a week without charging the battery at all. As long as your alternator system is working correctly, no modern car should require a battery charger for only a weeks worth of inactivity.
Old Sep 7, 2023 | 07:56 AM
chrunck's Avatar
chrunck
None of the above. It will be just fine.
Old Sep 7, 2023 | 01:51 PM
cjv2's Avatar
cjv2
I believe TIS puts the line (for showrooms) at leaving a car sitting with no charging activity at 6 weeks. So a week should be fine. In theory. So long as you don't make it mad. Be sure to leave it some chips or something so that it doesn't feel neglected and get mad.
Old Sep 8, 2023 | 05:56 AM
RockC's Avatar
RockC
Have left other cars sit for a week or more -- one nearly 3 weeks -- while I was out of town. All were fine with one exception. With one car I left an OBD2 code reader plugged in. When I got back battery so low it would not crank the engine.
But that really was not due to sitting unused a week, but sitting unused with a parasitic electrical load.
I have to add that in all cases the battery was in good condition. And the cars had received enough use before being left unused a week+ that the battery was topped up. A battery starting out with a low charge and with some miles/time on the battery may not fare as well being left to sit a week.
Besides making sure to use the car a good amount before parking it I like to park it with a full fuel tank.
Be sure when you park the car all electrical loads are removed. Don't do like I did and leave something plugged in to the car. And lock the car which puts the car's electronics in their lowest power mode. Has never been a problem with me because my cars are parked some distance from my residence, but if the car in question has keyless/comfort access store the keys far enough away from the car that the car's security system is not able to contact the keys.
Old Sep 8, 2023 | 12:25 PM
TVPostSound's Avatar
TVPostSound
When you come back from your week break, you'll have weak brakes!!!
Old Sep 9, 2023 | 04:55 AM
Stu-mon's Avatar
Stu-mon
with my Romondes Charger I charge the 27th of every mo. anyway SO.......
Old Sep 9, 2023 | 09:42 AM
russmini's Avatar
russmini
There have been some discussion in other forums that locking the car will reduce battery usage. I always lock my Mini in my garage.
Old Sep 10, 2023 | 05:15 AM
Stu-mon's Avatar
Stu-mon
I always lock car when not in it period, unless I'm workin' on something & sometimes even then.
SaltNPepa
Mar 4, 2009 06:18 AM
T&CMCSa
DC Metro MINIs (Archive)
Jan 31, 2008 03:39 PM
MrBlah
Jul 15, 2007 07:10 PM
koolmini
23
Apr 26, 2006 01:35 PM
