F55/F56 Anyone replaced a transmission?
Old Jun 15, 2023 | 04:02 PM
UnderWaterAce's Avatar
UnderWaterAce
I have come to the conclusion that the transmission in my B38 F55 is very close to giving out completely and needs to be replaced. I am aiming to get a used automatic and install it but have not seen any examples of similar work done online. It would be nice to rebuild any suspect components on the new transmission before it goes in as well. If anyone has pointers that would be appreciated.
Old Jun 15, 2023 | 05:25 PM
lonewolf170's Avatar
lonewolf170
How many miles do you have and why you think it's going out?
Old Jun 15, 2023 | 11:38 PM
UnderWaterAce
Just over 70k miles. Gears won’t engage anymore but all electrical and computer functions for the transmission work fine. It tries to engage but fails to transfer power to the ground and has a metallic pinging/grinding sound. No associated codes other than a code for the transmission module not being coded to the car, however it has been like that for 4 years at this point without issue. Changed the fluid recently and there were no metallic particles suspended in the fluid.
All these factors lead me to believe a new transmission is necessary which is incredibly expensive unfortunately.
Old Jun 16, 2023 | 06:40 AM
Not much on the newer auto transmissions. You cannot replace much of the internals.
You can get the pan and their is no filter now. We have the pan in aftermarket options. You Just change the fluid.
https://www.ecstuning.com/Search/Sit...h/24118627787/
Transmission Fluid Change:
https://www.northamericanmotoring.co...id-change.html
And parts needed.
Old Jun 16, 2023 | 12:20 PM
UnderWaterAce
I have not seen many places selling parts needed for a rebuild so it seems the only course of action is to buy a decent used unit.
And parts needed.
Old Jun 16, 2023 | 01:42 PM
Yes, no internals for that new transmission.
These are all the parts you can get:
https://www.realoem.com/bmw/enUS/par...Cooper_S&mg=24
and
https://www.realoem.com/bmw/enUS/sho...diagId=24_1492
Old Jun 17, 2023 | 01:10 PM
UnderWaterAce
Coding
Found a used transmission for a decent price that I am contemplating buying. Does anyone know what would be required to code the transmission to the car?
Old Jul 4, 2023 | 06:31 PM
UnderWaterAce
Picked up a used 47k mile transmission from a parts broker, hopefully it will work but I’ll see once I get to the install. I do believe I am the first 3rd gen owner on the forum to have an automatic transmission failure.
Old Jul 5, 2023 | 06:56 AM
Yep, have not heard much.
Old Jul 14, 2023 | 09:04 AM
cargusjoh's Avatar
cargusjoh
Is it possible your 3 cylinder was tuned? I also have not heard of a 3 cylinder transmission failure on Facebook, here at NAM, or MINF56.com. Plewase keep us up to date!
Old Jul 14, 2023 | 09:47 AM
UnderWaterAce
I am fairly confident it is not tuned but to tell the truth I have not checked. I am suspecting it’s an internal leak in the transmission since it seems to slip out due to a lack of pressure keeping the gears together when torque increases past a certain threshold, but only in certain gears eg. 5th and 6th. Unfortunately there are no internal rebuild kits for this transmission from what I have seen. It’s possible the TCU has faulty programming because, compared to another 3rd gen automatic I drove, mine is far more coarse and aggressively vibrating than the car at the dealership. It may also explain why my average mpg was 18mpg, a value I thought was normal for the way I drive lol.
Old Jul 28, 2023 | 05:12 PM
UnderWaterAce
Got a second opinion on the transmission issue. Shop suggested it may be the passenger side axle slipping out of the transmission spline. They showed me a picture of the axle displaced a few inches toward the wheel. If the transmission splines are damaged it will call for a replacement trans anyway. In the meantime the car still works with 250ml of liqui moly atf additive in the transmission (overfilled).
Old May 18, 2025 | 11:55 AM
noahfrancis23's Avatar
noahfrancis23
Similar situation now
Was wondering how much info you were able to find on swapping the transmission in an f56? Im going through a similar situation where my clutch is slipping in my automatic at 112k miles. I need help sourcing a transmission, and about how much was spent?
zender1986
May 23, 2022 04:37 PM
DDodge
Feb 8, 2018 09:53 AM
dm33
May 7, 2016 06:09 PM
Misc
Oct 23, 2015 04:43 AM
