F55/F56 Wiper Arm Removal?
Old Oct 24, 2020 | 08:26 AM
NamBot3000's Avatar
NamBot3000
Wiper Arm Removal?
How do the wiper arms come off? I'm trying to change my DP and the wiper arms just will not budge. I've removed the cap, the nut, and banged and pried for an hour and they aren't even loose.
Old Oct 24, 2020 | 08:30 AM
NamBot3000's Avatar
NamBot3000
and as soon as I posted this they popped off with almost no effort....
Old Oct 24, 2020 | 02:13 PM
sgscomps's Avatar
sgscomps
A wiper arm removal tool works the best, ECS Tuning has a few to choose from or Amazon.
Old Oct 25, 2020 | 06:39 AM
Arrivederci Zagato's Avatar
Arrivederci Zagato
They are impossible to get off aren't they? Nice time try using a rubber mallet to make them budge.
Old Oct 25, 2020 | 02:00 PM
Capt_bj's Avatar
Capt_bj
wiper arms are typically pressed onto a splined shaft
if they don't come off easy the correct tool is a 'gear puller'
Old Oct 26, 2020 | 05:16 AM
NamBot3000's Avatar
NamBot3000
Thanks for this. After I got them off I thought "I could've used a gear puller", looks like a wiper arm removal tool is pretty much the same thing. I'll pick up one of these if I ever decide to change a DP again.....which is feeling unlikely at the moment.
Old Oct 26, 2020 | 05:17 AM
NamBot3000's Avatar
NamBot3000
Totally should have used one of these. I could have even rented one from Autozone.
Old Oct 28, 2020 | 09:52 AM
hadjiikong's Avatar
hadjiikong
I have always loosened the nut and tapped it with a dead blow hammer to get it lose. Then it pops right off.
Old Oct 28, 2020 | 09:15 PM
J_L's Avatar
J_L
Mine wouldn't come off, so I let PB Blaster soak on there for like 10 min. Came right off on the next try. I will get a puller if I envision another need to remove them, they're only like $10 on Amazon.
Old Sep 16, 2023 | 09:09 AM
cjv2's Avatar
cjv2
I know I'm "necroing" this thread, but just watch, and as they say, "wait for it." You may end up appreciating this video for life.
Old Sep 17, 2023 | 08:05 AM
NamBot3000's Avatar
NamBot3000
https://www.youtube.com/watch?v=62J7n09A8zk
Nice! Thanks for sharing that.
Old Sep 18, 2023 | 10:39 AM
This one works ok. https://www.ecstuning.com/b-schwaben.../023437sch01a/
I really like this design as its more study and you can use it on other things, also you can get on it easier and line it up: https://www.ecstuning.com/b-bav-auto.../b8800093~bav/
Just make sure you hit it with some PB blaster before hand. Make sure when you install to line it up on the old threads and push down and tighten with the screw, if not all the way on, it will strip the arm threads.
Old Sep 18, 2023 | 10:45 AM
cjv2's Avatar
cjv2
Geez, I actually have one of the first one (or same design) in a box somewhere. Picked it up over a decade ago. Which is why it's in a box "somewhere."
Wackiest thing, I finally got the courage up to mess with this last night. Found the nuts were not seriously torqued down. On a bit of a physics hunch, unscrewed them just enough to allow me to wiggle the wiper arms by hand, have some play, but not enough to "over-lever them" if that makes sense. Basically, they were either going to move a little and pop or not move at all, vs deforming or whatever.
Lo and behold, a couple of wiggles and... pop.
I will say that mine are alarmingly clean (I'm half-tempted to use anti-seize on reinstall). And since my windshield is not original (don't know when it was replaced but it was before 72K under the first owner) these have been off the car at least once before. So I don't know how illustrative my experience is. But it is interesting, given that the car has over 100K miles now.
mini-is-for-me
Oct 24, 2019 05:45 AM
TheBigNewt
Aug 27, 2013 04:48 PM
lovethecorners
May 10, 2013 07:43 PM
TaylorL99
Apr 24, 2008 04:05 PM
parzifal
15
Sep 1, 2006 12:30 PM
