F55/F56 Engine Air Filter and Cabin Filter
Old Oct 5, 2020 | 04:51 PM
spyked's Avatar
spyked
Hi all. I have a 2017 F55 S. I have had it since new. Not even 17k miles but 3 year maintenance plan is done. I need to change the engine air filter (B46?) and the cabin air filter. Is there a kit out there that has both of those items, along with DIY instructions? I look at OutMotoring and don't see engine air filters, only cabin. And then other places have different brands for both, and I'm spoiled for choice.
Is everyone just using MINI branded air filters for engine and cabin? Where are you getting them? Easy to change yourself? Thanks!
Old Oct 5, 2020 | 06:03 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
For the engine air filter we use the high flow dry filter. Like a K&N, but no oil to go through the sensors, but still high flow and lifetime so you can just clean it in the future.
https://www.waymotorworks.com/dry-pa...-f56-mini.html
And then the cabin filters. FYI these are not a 5min job so you'll need a friend that has done it before, or the instructions from the repair manual.
https://www.waymotorworks.com/cabin-...-f57-mini.html
Old Oct 7, 2020 | 02:51 PM
TVPostSound's Avatar
TVPostSound
Notice Way said cabin filters (plural) there are 2 stacked in there!!
Piece of cake, if you are a yoga master!!!
Old Oct 16, 2020 | 11:40 AM
SmittyRN's Avatar
SmittyRN
From WMW product page.... "These are suppose to be replaced once a year and an easy do it yourself job."
We gonna learn today!
Old Oct 20, 2020 | 06:05 PM
COkid's Avatar
COkid
You do need to be a bit of a contortionist by it's definitely a DIY job.
Remove one Torx screw on the left side of the passenger's footwell.
Pull off the side panel. There are several clips but only one screw. Be careful not to pull the wire for the light.
Unclip the footwell light.
Locate and unsnap cover high near the firewall.
Tug, pull, yank, drag, and remove the two filters.
Slide in the new filters.
Reclip the light wire and reinstall the side panel.
It'll drive you a bit crazy but it's doable.
Old Apr 2, 2022 | 09:15 PM
2014MCS_Miami's Avatar
2014MCS_Miami
Old thread, but I need an engine filter!
Do you offer members of this forum and discounts?
Old Jul 10, 2022 | 04:00 PM
David9962000's Avatar
David9962000
I'm changing my engine air filter. Mann makes one with and without the foam at the bottom. Which one do you recommend and what is the foam for?
Parts numbers:
With foam Mann C22018
Without Mann C22017
Thank you.
Old Jul 10, 2022 | 05:07 PM
TVPostSound
Parts numbers:
Without Mann C22017
Thank you.
The foam is for winter. Any icing would occur on the foam, and melt away. If ice were to form on the paper, the filter would be ruined.
Old Jul 11, 2022 | 03:59 AM
Stu-mon's Avatar
Stu-mon
as far as cabin filter goes : PureAirFlow.com might have one with a video of How I hear. they advertized on t.v. but I haven't looked yet. as far as engine filter goes my F-56 came with NM low-restriction installed & Forge intake pipe.clean yearly
Old Jul 12, 2022 | 04:09 PM
Scypio's Avatar
Scypio
Did both the cabin air filters and engine filters recently.
The cabin wasn't too bad, but I was used to changing my wife's Mazda3 which is pretty much in the same spot. The worst part is that you have to bend the second filter to get it in so I hope it popped back to shape. My neck was a little sore afterwards, but the old filters did have visible discoloration on them. I replaced the engine air filter with a K&N (I know controversial). When I removed the old filter, some of the foam was coming apart, there were bugs stuck in it, and the air box was dirtier than I imagined it should be (~3 years, <20k miles). And I'm pretty sure they changed my air filter during an oil change previously. (I asked them to change the cabin air filter and engine air filter at my last "early" oil change since my car is coming out of free maintenance but no dice.) And of course, I dropped a screw so this quick change took too long. But based on the condition of both filters, I'm pretty happy that I did it.
Old Jul 12, 2022 | 05:01 PM
TVPostSound
Way
Are these AFe filters??
AustinAggie
Nov 25, 2013 12:38 PM
pico33
Sep 23, 2013 06:35 PM
fullymooned
Mar 11, 2012 08:39 PM
JAB 67
Dec 10, 2007 05:25 AM
LordOfTheFlies
Nov 30, 2005 04:07 AM
