F55/F56 Big Pair
Old Apr 7, 2020 | 08:14 AM
Don Ottosen's Avatar
Don Ottosen
Big Pair
I was looking at the "Big Pair" for F56 base was wanting positive or negative experience on the product. Worth the 200 buck? Help under steering? Body Roll? Any advice would be great. TIA.
Old Apr 7, 2020 | 08:50 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We've installed many sets of the chassis braces on the F56 and for as easy and affordable as they are it's worth it as you will feel the slight different in how stiff the chassis is.
We also offer a few other brands that some are more expensive and some that are actually cheaper.
https://www.waymotorworks.com/chassi...5-f56-f57.html
https://www.waymotorworks.com/craven...-f56-mini.html
https://www.waymotorworks.com/forge-...-f56-mini.html
Old Apr 7, 2020 | 09:29 AM
USA-RET's Avatar
USA-RET
Clicked on this thinking it was something else. Disappointed.........
Old Apr 7, 2020 | 03:30 PM
rtowell's Avatar
rtowell
Absolutely worth it ... it's an inexpensive mod that you will feel immediately.
Old Apr 7, 2020 | 11:36 PM
ST107's Avatar
ST107
Would you say they all work the same? Are the more expensive ones better?
Old Apr 8, 2020 | 03:57 AM
Don Ottosen
Being I the market for them. I look at it as there are three options. There is less material on the chassis bone,crave speed and forge has been a long running So what's your budget? Yes they all do the same. Replace a part that worked but can be improved.
Old Apr 8, 2020 | 09:13 AM
WayMotorWorks
Vendor
I've installed both the Craven and Chassis Bone pairs here in my shop and I think they work equally.
The both have the angles cut into them to give them strength and the CV pair curve is a little lighter but I feel they work just as well as the curved edges may give it more strength, but that is for some engineer to ponder over.
Old Apr 10, 2020 | 08:25 AM
aslondon's Avatar
aslondon
EZ install and I found it to make a significant difference in handling. The car seems for alive and rigid. I didnt realize how "loose" the car felt until i installed the Cravenspeed brackets. To me it was well worth the time effort and money. I would do it again without hesitation
Al
Old Apr 20, 2020 | 07:20 AM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
In terms of an easy mod, this is that for sure. Here is the write up I did on them a while ago. - https://myredmini.com/the-big-pair/
Old Apr 20, 2020 | 07:35 AM
Fly'n Brick's Avatar
Fly'n Brick
Originally Posted by usa-ret
clicked on this thinking it was something else. Disappointed.........
+1
Old Apr 20, 2020 | 12:35 PM
tc1728's Avatar
tc1728
Thanks Vinnie, spent almost an hour on your page. Very nice!
Old May 11, 2020 | 06:11 AM
Don Ottosen
Well ordered a set on chassis bones installing this week. Will update with my opinion of the performance of this product.
Old May 13, 2020 | 11:57 AM
Mini_Vinnie
Moderator
Thank you my friend! @tc1728
Old May 22, 2020 | 01:50 PM
bratling's Avatar
bratling
Super Moderator
I’m sure you’ll like it. Adding the trio of Chassis Bones to my four-door F55 made an immediately noticeable difference. When you take off the factory sheet metal braces and compare them, the reason for the difference in handling is clear.
the rear (small) one especially — it literally holds the rear suspension in place side to side:
just compare...
thanks to Way for hooking me up with these. Great service as always... and I’ve never met him! Someday, maybe. 🙂
Old May 22, 2020 | 01:58 PM
ASKtheteach's Avatar
ASKtheteach
A friend is an MA at my MINI dealership. They just got in a GP3 and he took some pics of it today. Check out the factory chassis bracing. Very beefy! Unfortunately you need a VIN to order GP parts or I would already have them on order.
Old May 23, 2020 | 05:35 AM
Don Ottosen
just compare...
finely got to putting them on and get off winter wheel and tires. I didn't get to experience them with the small tires. But wow there is a difference on the curves on my route to work. Going from 15" to 17" and more tire contact this was way worth the investment.
Old May 29, 2020 | 09:40 AM
bratling's Avatar
bratling
Super Moderator
I suspect most of what you feel is the wider, lower profile tires, not the chassis reinforcements. Regardless, glad to hear you like your changes!
Surfer
Apr 4, 2019 05:07 PM
Alexander Major
Jul 31, 2014 10:29 AM
Acrofilo
Jun 27, 2014 09:39 PM
SoCalledFriend
Mar 12, 2014 05:17 PM
