F55/F56 Clutch pedal adjustment
Old Jul 4, 2019 | 06:42 AM
jpbpe's Avatar
jpbpe
Clutch on my 2014 F56 (44kmiles) requires push almost to the floor to disengage; this make shifting slow and difficult. Can this be adjusted to engage higher???
Old Jul 4, 2019 | 04:36 PM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
It sounds like it might be time for a new clutch
I was going to suggest a bump stop but it might stop it from engaging if you have to push it that far down
Old Jul 5, 2019 | 05:00 AM
hadjiikong's Avatar
hadjiikong
The slave cylinder may just need to be bled or that could be going out.
Old Jul 6, 2019 | 10:35 AM
jpbpe's Avatar
jpbpe
Thanks for the suggestion. I don't have/can't find a manual for my 2014 F56. How do I adjust/bleed the clutch slave cylinder? Is there a decent DIY manual available? Thanks to all!!!
Old Jul 6, 2019 | 10:46 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
newtis.info although I haven't checked to see if it covers what you need.
Old Jul 6, 2019 | 11:34 AM
jpbpe's Avatar
jpbpe
thanks minnnie that's more than I had before and looks like just what I need...
Old Jul 7, 2019 | 07:59 AM
N0B0DY's Avatar
N0B0DY
I haven't bled the slave cylinder on a MINI but I have done it on a Miata. It's kinda like bleeding the brakes. You hold the clutch down and loosen the bleeder on the slave cylinder and then close it before lifting off the clutch. Repeat as needed. The Miata also had a way to adjust the clutch engagement at the peddle.
Old Jul 30, 2019 | 08:14 AM
jpbpe's Avatar
jpbpe
I finally bled the clutch slave cylinder and found NO AIR, so the clutch still is unsatisfactory. I have to go to the floor to disengage and shift. Is there a simple way to inspect the clutch disc to see if it's worn out? Thanks
Old Aug 2, 2019 | 05:43 AM
David Baker's Avatar
David Baker
That's actually what I prefer. On my R50 that I did a 6 speed swap in, the engagement point is about an inch off the floorboard,which I like. Much less pedal movement when launching the car or shifting gears. Besides, a worn clutch will typically engage/disengage at the top of the pedal movement, not at the bottom.
Danscrazyhair
Oct 3, 2016 12:57 PM
DrewWphoto
Jun 3, 2016 05:27 PM
Tab32
Dec 28, 2013 11:37 PM
iguanad
Cooper (non S)
Mar 6, 2011 10:46 AM
dwm
Nov 21, 2006 12:07 AM
