F55/F56 Help ME Please
Old Jun 22, 2019 | 05:28 PM
DoubleNick's Avatar
DoubleNick
Help ME Please
Picked up a new MINI today. When I turned off the engine the ignition switch keeps flashing red, is this normal?
Help. Thanks
Old Jun 22, 2019 | 05:41 PM
DoubleNick's Avatar
DoubleNick
Thank goodness it turned off. I guess it was on for at least 10 minutes. Once I can figure out the onfotainmentstuff.I thought the dealer set for 10 minutes. Any insights, would be helpful . My older MINIS weren’t jazzed up like this one.
Old Jun 22, 2019 | 11:09 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Double tap off, not one.
Old Jun 23, 2019 | 04:30 AM
DoubleNick's Avatar
DoubleNick
Thanks MM. I was brain dead after getting briefed on the info at the dealer. TMI for me to process. I promise I will read the manual. Nick
Old Jun 23, 2019 | 06:16 AM
spyked's Avatar
spyked
Hit the switch TWICE but foot must be off the brake each time. Or it start ignition cycle again.
Old Jun 23, 2019 | 06:42 AM
Warren2185's Avatar
Warren2185
Don't feel bad. I couldn't figure out how I lost my digital speed read-out and it wouldn't come back. I stopped at the dealer. He explained the turn signal stalk button cycles back through to get it.
Ugh...I was totally embarrassed. My only defense (all-be-it a weak defense) was, from my drivers view, I couldn't see the print on the stalk to realize there were two separate buttons on it. I actually did try to push it (I was guessing at anything) but my finger was on the tiny divider between the buttons and nothing was happening. And I've owned this thing for two months. Humiliating...
So, no harm asking anything here.
Old Jun 23, 2019 | 10:44 AM
DoubleNick's Avatar
DoubleNick
Thanks for the info. Foot off the brake.Necessary info. Appreciate you folks.
Old Jun 23, 2019 | 12:31 PM
TVPostSound's Avatar
TVPostSound
Go outside and lock the doors. Everything will turn off!!!
Old Jun 23, 2019 | 12:48 PM
DoubleNick's Avatar
DoubleNick
Super, that makes sense. I park the car in my garage. I will now lock it. Thanks.
Old Jun 23, 2019 | 01:20 PM
bratling's Avatar
bratling
Super Moderator
In addition to the other notes, you can actually close and lock the doors and that will turn off the red light too.
Basically, this is like the “accessory” position on an old turn-key ignition, which had four positions (off, accessory, engine power, ignition).
Don't feel to bad, I think we all had something like this. For months I was convinced I had to do the second press or the whole system would stay on. The car is smarter than I am, as it turns out.
Old Jun 23, 2019 | 02:04 PM
DoubleNick's Avatar
DoubleNick
Well, it appears the only way the red light around the ignition goes off- only after I close and lock the doors. If I forget to lock the doors ie. In the garage does it finally turn off on its’ own? How long before it turns off on its’ own?Does that draw much battery?
I have noticed no difference with my foot on the brake or off. The light does not extinguish after 2 clicks. . I have a manual, not sure if the brake thing may work with auto, and not manual.
What started as a simple solution, seems to be getting more complicated
My quest for truth continues. Learned, experienced ones please share. Thanks. Nick
Old Jun 24, 2019 | 07:49 PM
N0B0DY's Avatar
N0B0DY
Wait until you notice the whirring noise when you open the door. Just know that the car will eventually go to sleep and the lights will go off. Takes about 5 minutes.
Old Jun 25, 2019 | 04:52 AM
DoubleNick's Avatar
DoubleNick
Thanks. I also have learned after about 5 min the flashing stops and the car goes to sleep.
Old Jun 25, 2019 | 09:14 AM
JosephM635's Avatar
JosephM635
I believe this is the "Heartbeat" option you are experiencing. If I remember right you can select an on/off for the "Heartbeat" in your settings for the center display. I can check later when I'm in my car and verify later.
Old Jun 25, 2019 | 05:21 PM
DoubleNick's Avatar
DoubleNick
Thanks. You are right. The heartbeat. When you get a chance please post how to turn off. I got so stuck on this I haven”t really got into the meat of all this car can do. I did get it tinted today. Also figured out if I turn off the DSC, keep in sport and use the BT Pro exhaust button the bad boy is fantastic music to my aging ears. Just love it. No need for exhaust mods. Nick
Old Jun 26, 2019 | 12:34 PM
" If you want to turn off the heartbeat, on the headunit, go to SETTINGS --> CENTER INSTRUMENT --> EVENT DISPLAY and uncheck "Heartbeat". You can also enable/disable other events the light ring reacts to. "
Old Jun 26, 2019 | 02:09 PM
DoubleNick's Avatar
DoubleNick
Thank you. Appreciate the help.
Old Jun 26, 2019 | 02:14 PM
Welcome.
phungshum
Nov 28, 2012 03:07 PM
Cary Cooper
Apr 9, 2012 07:05 AM
Zhenya13
May 11, 2009 11:02 AM
05TurboS2K
Jan 26, 2008 08:58 AM
flav
May 5, 2005 01:38 PM
