F55/F56 What tires should I run with this setup?
Old Feb 15, 2019 | 08:24 AM
F56Matt's Avatar
F56Matt
I am looking to drop my F56 3 door about an inch to an inch and a half at most. The wheel specs I'm looking at are 17x9 +30. What tires should I run in order to clear without rubbing? Trying to keep the stretching to a minimum, but if I have to stretch, there's not much I can do about it. I'm also about to be tuned for 260hp so these tires need to be able to handle the power. I'm open to different wheel specs aswell so post up your current tire and wheel setups.
Old Feb 15, 2019 | 11:32 AM
J_L's Avatar
J_L
You're way off. +30 is going to poke out a lot. There are several threads on wheel fitment, do some reading there.
Old Feb 15, 2019 | 06:31 PM
iwashmycar's Avatar
iwashmycar
You will stick out over an inch more than these (8" wide et45)
You will need to stretch, slam, and camber that shiz to get anything near 'fitting'
Old Feb 16, 2019 | 05:04 AM
cmt52663's Avatar
cmt52663
Try this one?
Cheers,
Charlie
Old Feb 17, 2019 | 07:14 PM
masternut's Avatar
masternut
Track spokes
Clarkm
Dec 30, 2017 08:20 AM
VtwinPower
Suspension
Sep 12, 2011 02:38 PM
fr1sco
Dec 13, 2009 07:24 AM
ctownsend
Tires, Wheels, & Brakes
May 1, 2003 04:06 PM
