F55/F56 About to add JCW Tuning Kit... Questions
#26
Originally Posted by Loccusst
If you get an aftermarket tune does it stack on top of the JCW tune? In other words, JCW tune puts you at 208 and you add a 30HP tune you now have a 238 tune or does it ignore the JCW tune to just add the 30 to the stock HP?
A "tune" usually means changing some of the engine computer's parameters, or instructions.
A "piggyback" is some sort of hardware that intercepts sensor data on its way to the engine computer, and changes that data.
So, tunes don't stack -- the engine computer only has one set of instructions. (Ignore for now a couple of exception conditions, such as GREEN mode.) if you get a JCW tune installed, then a Bytetronik tune, the BT replaces the JCW.
Piggybacks can stack on a tune. People have seen very good results from getting the JCW tune then putting a piggyback (NM, Dinan, etc.) onto the engine.
However not all tunes can be safely stacked this way. The JCW tune is relatively mild and conservative, so if you lie to it with a piggyback module, you'll still be well within the engine's safety limits. But get an aggressive tune, and you should not add a piggyback -- once you start feeding false data to a system already pushing the edge of the safe performance envelope, things get real sketchy real fast.
Hope this helps!
Loccusst (09-05-2018)
#27
As an S model, you already have the "first" tune, Sport Mode. I had a NM on my S and decided to go with the JCW tune solo (NM for sale BTW). For me, it seems much better than the NM. The torque range feels wider and more controlled than just front wheel spin with the NM. The tune presses me into the sport seats 2-5 gears. Speed isn't everything. It is just one of many components.
#28
I'll check my Carbon later today when I get off of work to see if those screens are different. I went into green once on the highway on a very crappy road to try and get a softer ride but other than that I never go there. I am curious to get this car on a long haul on the highway and see if open exhaust gets me better gas milage.
Go green, w/pipes open on trips or puttering around. In green things like AC are cycled differently, plus chip settings for mpg. Even at 75-80mph. Going to Mini On The Mack last year, my wife and I (plus gear) avg 39mpg. Spurts over 40mpg. I also agree with others, in mid mode, with pipe open, better performance and mpg.
#29
Within the next couple weeks, I'm going to schedule the JCW Tuning Kit installation. I'm familiar with the improvements it makes over all. Increased HP, Exhaust selector, etc...
Questions:
Are there any visible changes that I'll see in the Control Display?
Meaning, the lbs torque, and hp displays on the Driving Experience display. Currently HP only displays up to 200. With the JCW Tuning Kit, it's possible to produce more.
Any other new display screens for JCW?
When I'm in GREEN and MID mode, will there be any changes? Sound, Performance, MPG usage, etc...
Questions:
EnjoyRC (09-05-2018)
#30
Today is the day I'm dropping my MINI off at the MINI for the JCW Tuning Kit installation.
Quick question: Where to have MINI apply the JCW emblem on the tailgate during my JCW Tuning Kit upgrade?
The instructions indicate a much higher location than my CooperS logo on the right side. My first reaction is the vertical measurement should be equal to the measurement to the bottom of the CooperS emblem. Or do I leave it in the default location indicated in the instructions? What do you think?
#31
Tell them what you want and they should do it, I like the old school match to match horizontal for the JCW Tuning kits on the R53 and R56 platform.
#32
#33
I have seen them do special things for owners time to time. On that its a simple change.
#34
musicguy80210
04-01-2013 08:33 PM
bmwbrandon
03-08-2013 07:48 PM
