F55/F56 Lug Nut torque specs
Old Jun 30, 2018 | 12:28 PM
spyked's Avatar
spyked
Hi all. I am upgrading to the 17" Cosmos wheels from 16" loop spoke. My owners manual only mentions wheel nut torque specs for a spare tire (101). Does anyone know how tight I should torque the wheel nuts for on these wheels?
Also - just confirming, since I have the 16" tire pressure label, I checked my OM and it says: for under 100 mph and 5 door S with 17" wheels, the pressures should be 39 psi, cold. Is that what your tire pressure label card says if you have 17" wheels?
Can I get a new tire pressure label? Does anyone bother with that when they change wheels?
Thanks!
Old Jun 30, 2018 | 01:15 PM
TVPostSound's Avatar
TVPostSound
103 Ft lbs
Start with 50 ft lbs in a 1/3/5/2/4 pattern, then go back again at 101ft lbs.
Best done without weight on the wheels.
I have the 17" Cosmos, and the label says 38 F 35 R
Old Jun 30, 2018 | 01:16 PM
TVPostSound
But I have an F56
Old Jun 30, 2018 | 01:56 PM
spyked's Avatar
spyked
Thanks for the quick reply. Appreciate it!
Old Jun 30, 2018 | 02:46 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
The tightening torque is 101 lb ft/140 Nm. 2014 F56 Owners Manual
It is exactly the same as you will find in the 2017 F55 Manual
Check Mobility section of your owners manual for correct tire pressure, it isn't the same from F56 to F55S.
Old Jun 30, 2018 | 03:24 PM
spyked's Avatar
spyked
Thanks. On page 202 of my OM for 2017 model, it says 101/140, but that is the section and instructions for mounting an emergency wheel (the spare that they offer under the hatch floor). I wasn't sure if the same specs applied to a non-emergency wheel. Not referenced in the 2017 manual for some reason. I guess they made amendments from the 2014 book. Probably don't want DIYers.
Its page 189 where I find the tire pressure info for F55 S model. 39/39 for speeds under 100 mph.
Old Jun 30, 2018 | 05:58 PM
TVPostSound
Check here, they update the manuals here.
https://www.miniusa.com/owners/tools...r-manuals.html
CalsonicSE
May 20, 2019 03:13 AM
drewie
Tires, Wheels, & Brakes
17
Mar 5, 2011 11:00 AM
quemas
Aug 26, 2010 09:14 AM
MeloR56
Jun 22, 2008 12:58 PM
