F55/F56 Does the F56 drip a/c condensation?
Old Jun 27, 2016 | 02:42 PM
spyked's Avatar
spyked
I live in a very humid environment. I always see the water dripping from A/C use in my other cars. Harmless, no biggie. But I notice my F56 does not drip. Yet I have no bad smells or wet carpets. Where is the condensation going if not on my driveway?
Old Jun 27, 2016 | 03:13 PM
ShadowImg's Avatar
ShadowImg
We've only had the F57 for a couple days, but we picked it up on a ~90 deg humid day. It was pissing like a racehorse. Enough that I actually checked to make sure it wasn't overfilled with coolant.
I think the F56 is similar enough that it would do the same.
Old Jun 27, 2016 | 03:15 PM
anotherminiinthegarage's Avatar
Ouu F56 hardtop drips on humid days in AZ
Old Jun 27, 2016 | 03:27 PM
spyked's Avatar
spyked
Hmm, I'll have to keep this on my list of things to think about. It's an April 2016 build date, with May delivery. Can't be clogged up yet...only 900 miles on it.
Thanks for replies.
Old Jun 27, 2016 | 08:59 PM
Fly'n Brick's Avatar
Fly'n Brick
ALL air conditioners create condensation and it has to go somewhere.
Old Jun 27, 2016 | 11:46 PM
Sidewalker's Avatar
Sidewalker
On a road trip to Houston this last week, we noticed a very wet carpet in my wife's car...upon closer inspection, there was actually mold growing around the pedals underneath the carpet. We dropped the car off this morning at the dealer...it's clear the condensation is coming into footwell of the driver side. No diagnosis yet...
Old Jun 28, 2016 | 08:38 AM
USA-RET's Avatar
USA-RET
Had the same thing happen to me. Caught it early. Kinked drain line from the evaporator. Easy fix. Long delay was due to the having to pull the carpet and get it dried thoroughly. With mold in yours, I'd demand new carpets.
As to the AC water, I've yet to see any spots on the garage floor and being in SW Florida, we have humidity up the "Wasue".
My C7 drips AC condensation but I can hear it hitting the exhaust and it never gets to the floor. Mini makes no sound of water sizzling..so maybe it's going into the windshield washer reservoir .
Old Jun 28, 2016 | 01:59 PM
spyked's Avatar
spyked
Here in VA, we are downright swampy/soupy with humidity at times. Ran A/C all the way home from work and driveway is dry as the desert. No wet carpets, no bad smells, HVAC seems to work fine. I'm either going to get a major flood soon, or the drips are just evaporating somehow.
Old Jun 28, 2016 | 02:30 PM
vetsvette's Avatar
vetsvette
Moderator
Or collecting on the belly pan.
Old Jun 28, 2016 | 03:18 PM
spyked's Avatar
spyked
I never thought of that. Is the condensation drain directed into the belly pan by chance? That would make sense. The car is so small, I haven't gotten under it, but I'd imagine the belly pan must take up at least a 1/4 of the car's under carriage space.
Old Jun 30, 2016 | 09:20 PM
Sidewalker's Avatar
Sidewalker
Update from the service dept today, they were in the middle of diagnosing the issue. I asked for the carpet to be replaced, so hopefully they pitch the plan to Mini and get it approved. My advisor told me they will only do the work that Mini agrees to pay for, so if they don't replace the carpet entirely, I will push until they do. With mold, I don't want to deal with the issue a few months down the road.
Old Jul 1, 2016 | 09:18 AM
toyopet's Avatar
toyopet
For those who do notice AC condensation dripping onto the pavement, where do you see it? Driver's side front?
Old Jul 1, 2016 | 10:04 AM
ShadowImg's Avatar
ShadowImg
Yeah, seems to drain away mostly to the driver's side, though seems to drip near center, just behind or at the rear edge of the front tire.
Old Jul 1, 2016 | 02:38 PM
Its should on the drain that goes under the HVAC system on hot humid days you run the a/c allot.
http://www.realoem.com/bmw/enUS/show...diagId=64_2038
Old Jul 2, 2016 | 09:55 AM
toyopet's Avatar
toyopet
I'm in the same boat as you. I haven't seen any condensation on the pavement yet. But when running the ac on my Sienna for the same amount of time, I see plenty of water dripping.
Old Jul 6, 2016 | 04:56 PM
spyked's Avatar
spyked
In the middle of a heatwave here, high humidity, swampy conditions. Completely dry under the car. The embarrassing thing is, what would I even "complain" about at the dealer? They'd ask "is your a/c working?" I'd say yes and that would be that. Until the carpets are wet and moldy like others on here. Frustrating.
Old Jul 6, 2016 | 10:15 PM
Camyman's Avatar
Camyman
There is a drainage channel that runs down from it but it also runs right next to the turbocharger and the exhaust manifolds so it is really hot right in that area. Most people don't see it drip because of that. If you have the car sitting in a spot with the MAX A/C on it may get a little bit, but for the most part you're fine.
Just as a side note to the newer owners, there was a bulletin MINI put out for a bad smell coming from the A/C system, if this happens they need to disinfect the air box and replace the micro filter. Usually they will add a couple beads of hot glue to make the filter stand taller inside the box, I am not sure if they have a reworked box yet.
Old Jul 8, 2016 | 12:59 PM
perryinva's Avatar
perryinva
New (5/16 build) F54 here, and there is a small puddle under it in the garage. (I have that polyurethane diamond plate roll down flooring) I think most really may evaporate on the way though, because my R55, with fairly weak AC would leave (still does) a small river of condensate on the same spot. The F54 cools amazingly well, far, far better than the R55 ever did, but leaves less than a tenth as much. Not sure why otherwise.
bradstyle
Tires, Wheels, & Brakes
Jul 30, 2016 05:26 AM
Serchjcw
Jul 8, 2016 11:21 PM
Serchjcw
Jul 7, 2016 01:51 PM
fenderpicks
Jun 30, 2016 06:44 PM
BruceWarne
Jun 24, 2016 04:51 PM
