F55/F56 K&N Filter
Old Jun 23, 2016 | 06:06 AM
madmix's Avatar
madmix
K&N Filter
I am going to change out the air filter with a K&N on my Mini3s (justa). Has anyone had issues with throwing air flow sensor codes. My BMW used to throw codes every time I used a K&N.
Old Jun 23, 2016 | 10:24 AM
toyopet's Avatar
toyopet
I would go with the AFE Pro 5R. Part # 30-10256
*EDIT*
Part number is for the F56 S or JCW
Old Jun 23, 2016 | 10:29 AM
NullUnit60's Avatar
NullUnit60
I have had no problem in nearly a month since the install.
OOPS! I should clarify; I have the cold air intake, not simply the replacement filter.
Old Jun 23, 2016 | 10:55 AM
_ynot's Avatar
_ynot
I put one in my MCS a week ago, no issues with about 500 miles on it.
Old Jun 23, 2016 | 04:20 PM
jlb's Avatar
jlb
I've had mine ( drop in ) for about 8 months, no issues.
Old Jun 23, 2016 | 05:22 PM
Mini Mania's Avatar
Not a problem if you don't overcoat the filter after cleaning and re-oiling. Most new ones come pre-oiled so you don't have to worry.
Old Jun 23, 2016 | 08:07 PM
MarcoPolo's Avatar
MarcoPolo
to play it safe, may not hurt to throw up an obd2 bluetooth dongle and monitor the STFT and LTFT...typically when a LTFT hits 25, that's what typically triggers a CEL. OEM filter are pretty spot on @ 0, but i've seen my STFT hit 5 or so. with a K&N filter, i'd imagine seeing 10, which makes sense. anything above 15 and more than likely you'll eventually throw up a light.
Old Jun 24, 2016 | 02:05 AM
fradaj's Avatar
fradaj
I installed a dry AFE Pro a few months ago with no issues.
Old Jun 24, 2016 | 04:42 AM
Qik420's Avatar
Qik420
When I bought my MINI I stuck in an Alta drop in sponge filter which was oiled and had no issues, I installed this (pictured) K&N heat shielded filter almost 2 months ago and haven't had an issue yet. I did get a can of MAF sensor cleaner in case it causes one. Spray down the MAF with that and you're good to go.
Old Jul 7, 2016 | 01:12 PM
Joespeed's Avatar
Joespeed
*EDIT*
called everyone looking for the aFe dry filter...no luck... if anyine knows where to find it please let me know
Old Jul 7, 2016 | 01:35 PM
BillM's Avatar
BillM
That part number came up as a pre-oiled one that can be repeatedly cleaned.. Not sure if matches description of "dry".
Also I read quite a bit about K&N versus other filters and found several studies showing that if you're not willing to clean the K&N before it accumulates a significant amount of particle mass, you may see worse average flow than several paper style filters. The K&N data shows better initial flow but it drops off much quicker than paper filters as debris is collected. I may pass as I'm lazier than I like to admit.
Old Jul 8, 2016 | 03:02 AM
fradaj's Avatar
fradaj
I bought mine here. The 2.0 and 1.5 use the same air filter.
http://www.autoanything.com/air-filt...FQiqaQodBIYLpA
Old Jul 8, 2016 | 09:19 AM
Joespeed's Avatar
Joespeed
thanks.. i ordered from them yesterday, called them up because i had to change my delivery address, they told me these filters were in fact, not in stock..
search continues
Old Jul 8, 2016 | 12:23 PM
fradaj's Avatar
fradaj
search continues
It took a while to get mine, I think aFe had to manufacture it to fulfill the order. Mini Mania has them too.
Old Jul 8, 2016 | 02:06 PM
Joespeed's Avatar
Joespeed
thanks.. however , i dont see it on their site
http://new.minimania.com/ss/ENGINE-T...AIR_FILTERS_NM
Old Jul 8, 2016 | 10:19 PM
Mini Mania's Avatar
K&N interchangeable, have used both on my championship racing car.
Old Jul 9, 2016 | 10:00 AM
fradaj's Avatar
fradaj
I thought it was Mini Mania but it was actually Way Motor Works.
http://www.waymotorworks.com/dry-pan...-f56-mini.html
Old Jul 9, 2016 | 12:01 PM
Joespeed's Avatar
Joespeed
ty
seaphair
Apr 20, 2016 08:46 AM
ducatiorourke
Apr 19, 2016 01:04 PM
Jorge Cardona
Apr 11, 2016 07:41 AM
Frixos
Apr 3, 2016 06:12 PM
eJCW12
Electrical
Mar 27, 2016 03:12 PM
