F55/F56 2016 mini cooper base 3 cylinder 1.5L engine oil
Old Jun 21, 2016 | 02:37 PM
cal113's Avatar
cal113
Hi guys, I am about to do my first engine oil change, and can some one please tell me how many quarts doesn't the 3 cylinder engine takes? Mine is 2016 Mini Cooper base 2 door hardtop. Thanks you!
Old Jun 21, 2016 | 06:46 PM
ashchuckton's Avatar
ashchuckton
It is in your owners manual.
Old Jun 21, 2016 | 07:09 PM
cal113's Avatar
cal113
didn't find it in there
Old Jun 22, 2016 | 10:28 AM
ashchuckton
In your other post I recommended you call your dealers service dept. Crazy that the oil capacity is not in the manual.
Old Jun 22, 2016 | 10:33 AM
cal113's Avatar
cal113
Did some research, it should be 4.5 to 5 quarts
Old Jun 22, 2016 | 03:06 PM
Mini Mania's Avatar
Engine Oil
Should be 4.49 quarts. Here's an application guide. Please be sure to ask if we can help in any way!
http://new.minimania.com/part/NME725...55-F56-F57-F54
Old Jun 22, 2016 | 03:54 PM
cal113's Avatar
cal113
Just put exact 5 quarts in to my 2016 Mini Cooper base computer reads this (see pic). Is it perfect or I should fill the bar all the way up?
Attached Thumbnails 2016 mini cooper base 3 cylinder 1.5L engine oil-image-250099904.jpg
Old Jun 22, 2016 | 04:08 PM
Mini Mania's Avatar
oil
Since the spec is just under 4.5 quarts. I'd be sure the oil has had a chance to drain to the pan and you are parked on level ground.
Old Jun 22, 2016 | 04:19 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
There was a campaign to remove engine oil decals from engine bays of all 2014/2015 models. So far no new decals have been issued.
And pretty sure the 2016 F models have engine oil decals...Think it reads reads 0W-20, maybe OP can check theirs. Decal should be on engine cover.
Old Jun 22, 2016 | 05:25 PM
cal113's Avatar
cal113
I see people saying 4.5 is not enough on this forum. And they end up using 5
moremini
Apr 20, 2016 07:08 AM
Lucila
Apr 9, 2016 09:11 AM
JWA
Mar 20, 2016 04:29 PM
Number1
May 25, 2006 03:06 PM
gomini
Jun 6, 2002 03:37 PM
