F55/F56 New JCW F56 Dyno
Old Jun 26, 2015 | 05:00 PM
Terry @ BMS's Avatar
Terry @ BMS
New JCW F56 Dyno
Hey guys,
Just met up with a tuner friend of ours Jay at bytetronik.com to play around with his new MINI Cooper JCW. They're working on a flash tune for the platform, hard parts, etc, but to get the R&D ball rolling is running our Stage1 setup.
The car is 100% stock, automatic, running 91 octane fuel with 3 gallons of E85 mixed in.
The first thing I noticed under the hood was the new fuel pressure sensor connector I've been hearing about. Was nice to finally see one in person. Fortunately we have the new connectors in stock and we now have a compatible flex fuel connector system for it. I'll work on getting that on the site next week.
After some logging we found it runs around 15-16psi stock with today's 90 degree temps. And with the E85 mix we were able to easily turn it up another 5psi to 21psi. Which rewarded us with a nice 45whp and 49wtq gain over the stock baseline. Timing and AFR remained smooth throughout the tuned pulls.
Jay's working on a flash tune for the vehicle to do some things we can't do with a piggyback, like removing the speed limiter, and raising the fuel ceilings, and then we'll get back together in a collaborative way to design piggyback specific software meant to work with their flash for those MINI owners who want to really take it to the next level.
Old Jun 26, 2015 | 05:26 PM
craigsix's Avatar
craigsix
sounds great sign me up. im running +7 with ff cables and full race exhaust 98 octane and 3 gallons e85. the drivetrain malfunction is back so im running oem map connected.
Old Jun 26, 2015 | 05:42 PM
Terry @ BMS
To run those higher boost levels I suspect the back end flash map will be required. We'll see what Jay comes up with.
Old Jun 26, 2015 | 06:28 PM
knecht's Avatar
knecht
Thanks Terry! I really need to order the Stage 1! 😄
BTW - The Stage 1 has been around awhile is it still really considered Beta? No biggie, just curious
Old Jun 26, 2015 | 08:29 PM
e46jb's Avatar
e46jb
Looking forward to seeing what can be done......I am sure the JB4 for the MINI crowd will be just as popular as they are for BMW's
Old Jun 26, 2015 | 09:10 PM
Terry @ BMS
Yes
Old Jun 27, 2015 | 08:08 AM
randomquickness's Avatar
randomquickness
Looking good! If this stupid e34 would stop sucking up my car fund like a hoover i'd play with the MINI more.
Old Jun 27, 2015 | 09:20 AM
Falcon-Z's Avatar
Falcon-Z
I guess it confirms the S and JCW turbos are not the same. Running 21 psi even 15 psi is insane!
Old Jun 27, 2015 | 12:08 PM
craigsix's Avatar
craigsix
maybe he can fatten the afr and add more timing. more boost is good also. the jcw has lower compression so it can run higher boost levels i dont know about head gaskets or head bolt torque being different between the s and jcw. i can never have enough horspower or poontang! thanks
Old Jun 28, 2015 | 04:39 AM
jamesdean's Avatar
jamesdean
There are numerous folks running this psi on S models
Old Jun 28, 2015 | 11:25 AM
mct's Avatar
mct
Wow - impressive numbers for stock even!
Old Jul 5, 2015 | 11:23 AM
jetmechinnc's Avatar
jetmechinnc
Sounds all good for the JCW! Love the power it now has, particularly the passing power, course you can never have too much as long as you can put it down to the ground. Plus the fact that there may be a true refresh tune available sounds perfect. Only bad thing is that the web site seems to be down for bytetronik to look up any info there on their tune.
Old Jul 5, 2015 | 02:37 PM
jamesdean's Avatar
jamesdean
It is the same turbo BTW. JCW gets a oil cooler that the S does not and few engine adjusts. I may go JCW for my next one but happy with my 260bhp S for now.
Old Jul 5, 2015 | 05:54 PM
Ryephile's Avatar
Ryephile
Thanks for the baseline dyno, AFR trace, and the boost plot.
I'd like to see normal pump 91 and 93 octane tests. The fueling system components are not advertised for gasoline over E10, despite 1 or 2 people giving no mind to that.
Old Jul 6, 2015 | 11:53 AM
Bytetronik's Avatar
Bytetronik
We are in the process of switching hosting companies, at the same time, a revamp of the current website as well. So stay tuned...
Old Jul 6, 2015 | 11:58 AM
Bytetronik's Avatar
Bytetronik
We'll be updating the testing results with pure 91 octane soon... With the JB units, it's cool that we can add a few gallons of E85 and the car totally wakes up.
While the ECU reflashing option will be available soon, but that will likely be reserved for Track cars only. For street and weekend racers, we'll have a full line of JB units finalized in the near future. If you're interested in becoming a Beta Tester for 93 Octanes, PM us and we'll go from there.
Old Jul 6, 2015 | 12:36 PM
Ryephile's Avatar
Ryephile
Just understand not everyone wants to find out the hard way that the HPFP might not tolerate high ethanol percentages.
While the ECU reflashing option will be available soon, but that will likely be reserved for Track cars only. ....
Why limit your market so severely? Or are you "just sayin" that as an emissions disclaimer?
Back to the data, it's becoming more common [in other engines] to see more of the full-load RPM band to be Stoich. In this case, the AFR has a curious 3-tier AFR: Stoich to around 2,600 RPM, then "14:1" for the mid-range, and then pretty much peak torque AFR from 4,500 to redline. Of course, this graph is from a tailpipe sniffer, likely a LSU 4.2 et al, with unknown calibration.
To the dyno operator: Please log the full RPM band, from 1k RPM to fuel cut. Remember the peak torque is advertised at 1,250 RPM, which was missed with these pulls.
Old Jul 6, 2015 | 01:03 PM
jetmechinnc
While the ECU reflashing option will be available soon, but that will likely be reserved for Track cars only. For street and weekend racers, we'll have a full line of JB units finalized in the near future. If you're interested in becoming a Beta Tester for 93 Octanes, PM us and we'll go from there.[/QUOTE]
I'm guessing that to be a beta tester for just 93 octane petrol, you need to be on the west coast? I'm in North Carolina
Getting excited about this possible ECU upgrade to try it out at VIR raceway whenever it's done! Think my next track day will be in October with Phil Wicks.
Old Jul 22, 2015 | 01:32 PM
jetmechinnc
Any more news on the software tune for the JCW by ByteTronik
Old Jul 22, 2015 | 06:48 PM
toyopet's Avatar
toyopet
AFR is running very lean for forced induction. This is a quick way to kill the motor.
Old Jul 23, 2015 | 08:29 AM
Ryephile's Avatar
Ryephile
Generally speaking, that's untrue for current gen GDI's. OEM durability testing alone proves your opinion wrong.
FYI, some VAG TGDI engines run Stoich for 100% of operation. I recommend learning more about GDI engines before making a blanket statement likely rooted in old PFI engines that lack the chemical and mechanical quench to run at or near peak torque AFR.
Old Jul 23, 2015 | 09:16 AM
toyopet's Avatar
toyopet
I was referring to the AFR showing a leaner mixture at +5psi compared to stock which is not good in my opinion.
Also, OEM durability testing does not apply to engines running +5psi over stock using a tune or piggyback module. That's why warranties are voided if mfg finds out the ECU has been flashed.
Old Jul 23, 2015 | 09:41 AM
TheBigNewt's Avatar
TheBigNewt
I read on someone's R56 JCW post that he had the BMS device on the track, and has a boost guage in the car, and was getting 21-22. He was worried because evidently something can happen at >21 boost that shuts the car down???? It didn't do it to him though. He dialed the guage back a bit to avoid that he said.
Old Jul 23, 2015 | 11:22 AM
Ryephile's Avatar
Ryephile
You're misreading the graph. Since it's a Dynojet, a torquier pull means a shorter timespan, which will offset the AFR reading at the tailpipe in the time domain.
I assure you that your opinion or "lean", while perhaps applicable for PFI setups, is not directly correlative to what's happening in this example. This was a big problem with GDI's first came out, because all the aftermarket tuners were ignorant about the fueling strategy along with the technical details behind it. I'm afraid you're a bit behind the curve at this point.
Your assertion that OEM's only test at advertised power is inaccurate. Perhaps that's the case at your employer, but that's not applicable across the industry.
Old Jul 23, 2015 | 11:29 AM
Ryephile's Avatar
Ryephile
To go a step further, AFR's are hardly a fixed map anymore. Many engines, for example, now do time based enrichment at full load to regulate catalyst temperature and/or provide long-term chemical cooling. It's a tiny part of the strategy, and chances are you'll only see it on the track or in a standing mile, as most shops don't have a DynaPack with a cooling tower.
