F55/F56 Creaking from front end
Old Jun 4, 2015 | 05:15 PM
russmini's Avatar
russmini
I've been hearing a creaking sound from my front end at low speeds, always when I make a turn. It sounds a bit like bending a thin piece of metal. It only makes the sound when I make a turn from a stop sign or when I back out of my driveway and then turn the wheels. Any ideas what this is? 2014 Base MINI Hatchback, automatic and 16" wheels.
Old Jun 5, 2015 | 09:27 AM
bryce77's Avatar
bryce77
My 2014 hardtop does this too. Happens when making sharp left turns. I took it to the Dealer twice. They tighten some bolt on the front struts and its fixed for awhile then slowly comes back. For me the issue only happens when its cold out. Ill be complaining about it again next time im in for an oil change.
Old Jun 7, 2015 | 03:07 AM
jamesdean's Avatar
jamesdean
There is a bulletin out for the front strut bolt and bushing for certain cars. Mine made note like a rubbery. Bulletin fixed my issue.
Old Sep 15, 2015 | 08:47 PM
mct's Avatar
mct
Do you have the bulletin number for this?
Old Sep 16, 2015 | 01:54 AM
jamesdean's Avatar
jamesdean
I do not recall but they replaced my front struts under it.
Old Sep 16, 2015 | 07:51 AM
Check this one out also:
Issue - Wheel Hub Bolt 31206783065
https://www.northamericanmotoring.co...-hub-bolt.html
Old Sep 16, 2015 | 08:06 AM
mct's Avatar
mct
Mine actually had the creaking in the right front as well. Brought it in and they said there was a bulletin for adding additional lubrication to the rubber boot at the perch. They applied the lubrication and so far so good - creak is gone.
Old Sep 17, 2015 | 04:35 AM
g34343greg's Avatar
g34343greg
mine and the wife's (S and non-S) were both doing this on sharp left turns last winter, but not every day.
Old Dec 26, 2015 | 07:52 AM
honderpilot's Avatar
honderpilot
Mine is doing this too now. Made my own thread without searching first, glad I found this one. I will be taking the car in later this week.
Old Dec 27, 2015 | 03:01 PM
Skummdogg's Avatar
Skummdogg
Mine is doing this as well, haven't paid attention to which side it's coming from. It's only at low speeds, usually while backing. I'll be bringing it up when I go in for next service.
Old Dec 28, 2015 | 07:21 AM
Let us know if it was the bolt.
Old Dec 29, 2015 | 06:58 AM
mct's Avatar
mct
I found the source of the creak (in my car at least)!! There is a silicone tube that covers part of the spring in the front end. If the spring is set too low, it will cause a creak. Simply routing it upwards a bit so that it starts at the top at the 1 full 360 degree mark of the first coil, creak disappeared!! Moved the silicone tube lower and creak came back... At least for me, this was the source of my issue.
Old Dec 29, 2015 | 08:25 AM
honderpilot
Do you have aftermarket springs?
Old Dec 29, 2015 | 08:28 AM
mct's Avatar
mct
Yes - NM lowering springs
Old Dec 29, 2015 | 10:00 AM
honderpilot
This happened to me before when I first put them on. Is there anyway to prevent the silicone sleeve from sliding down or do I just have to readjust it every 2000 miles?
Old Dec 29, 2015 | 11:00 AM
mct's Avatar
mct
Good question. Mine don't slide down that often, but when I rotate my tires I make sure to re-adjust to be safe.
Old Dec 29, 2015 | 12:08 PM
honderpilot
I've had them on for about a year and this is the first time hearing the noise since. I'll have to find a way to secure them until then
Old Mar 20, 2020 | 10:39 PM
Imperial's Avatar
Imperial
Hey! I think mine makes a rubber noise when I turn left from the stop when in 1st or second gear. Basically a start to accelerate into the left turn and release gas pedal and noise is heard. I did capture the creaking noise.
Did anyone have this happen or fixed?
https://static.nhtsa.gov/odi/tsbs/20...46664-9999.pdf
grunte
R55 :: Clubman Talk (2008+)
Jun 3, 2019 07:13 PM
bassles
Tires, Wheels, & Brakes
27
Mar 7, 2015 10:05 PM
Stay Curious
Jul 3, 2014 07:49 PM
bassles
Apr 7, 2014 03:20 PM
Mrdi
Mar 24, 2014 04:18 AM
