F55/F56 Surprising new behaviour
Old Mar 6, 2015 | 04:52 AM
hammerhands's Avatar
hammerhands
After a quick check-in at work I drove 150 feet, stopped on an incline. My F56 automatic 3-cylinder was in mid-mode and it entered an auto-stop. I opened my door, in drive but foot still on the brake, closed the door and got a horn beeping, lights flashing warning that my car was in danger of rolling away.
I had to press the start button to restart the car. I drove around the lot again and noticed when I stopped and opened the door with the auto-stop engaged the display says goodbye or something.
I tried it a third time, and let my foot off the brake momentarily to disengage the auto-stop, then I was able to open the door.
Interesting!
Does the MINI One still have a key?
Old Mar 6, 2015 | 05:03 AM
carman63's Avatar
carman63
My BMW X1 behaves similarly. My wife and I were at a dealer after hours, looking at inventory. I'd stop, get out, and look at cars. If auto-stop kicked in, then when I left - with the key - I'd come back to a fully shut down X1. Happened every time, until I disabled start-stop. I believe it's the opening of the door that causes it.
It could be a combination of being in gear and auto-stop kicking in, but in my case I was always in Park.
Old Mar 6, 2015 | 07:39 AM
TheBigNewt's Avatar
TheBigNewt
But one can permanently disable the autostart right? By permanently I mean turn it off unless you decide to turn it on again. That feature is obnoxious and I don't remember anyone on this forum that likes it. I would doubt that it saves much gas if any. I you want to save gas buy a hybrid!
Old Mar 6, 2015 | 08:24 AM
carman63's Avatar
carman63
In my case, yes I can disable auto start-stop and the on-off state is changed until I change it back. I don't mind it, and would use it in my F56 when the time comes that I purchase one. I'm pretty sure F56 start-stop behavior is the same as my X1.
Old Mar 6, 2015 | 09:25 AM
TX1911fan's Avatar
TX1911fan
I've found the same thing. If my car auto stops then I put it in park and then I get out, I have to restart the car.
Old Mar 6, 2015 | 11:43 AM
siriuszero's Avatar
siriuszero
By design, if you have auto start/stop on and shift into park while the engine is off, it assumes you're leaving and shuts the car off.
Old Mar 6, 2015 | 12:09 PM
Kinetic89's Avatar
Kinetic89
Same thing happens if you leave the car while in neutral with a manual.
I actually don't mind the stop-start system.
Old Mar 6, 2015 | 01:00 PM
hammerhands
I like the auto start/stop.
In this case the car was never out of gear, foot was on the brake.
Old Mar 6, 2015 | 01:16 PM
anotherminiinthegarage's Avatar
Idiot ran into idiot-proofing
Old Mar 6, 2015 | 01:56 PM
hammerhands
Gfy
Old Mar 6, 2015 | 02:15 PM
siriuszero's Avatar
siriuszero
That's a bit rude...
twriter
Oct 2, 2015 03:14 PM
pkillur
Sep 26, 2015 01:57 PM
rt808
Sep 25, 2015 01:59 PM
ir0nhid3
Sep 18, 2015 07:52 AM
